1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: multiple servers on the same (loopback) interface
To: "'Jameson Graef Rollins'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 10 Jul 2013 14:01:09 +0000
Hi Jamie,
In fact, "ports can be specified in the CA_ADDR_LIST list" is DOCUMENTED: http://www.aps.anl.gov/epics/base/R3-14/8-docs/CAref.html
All Channel Access (CA) configuration occurs through EPICS environment variables. When searching for an EPICS environment variable EPICS first looks in the environment using the ANSI C getenv() call. If no matching variable exists then the default specified in the EPICS build system configuration files is used.
Name				Range					Default
EPICS_CA_ADDR_LIST	{N.N.N.N N.N.N.N:P ...}		<none>
If a client needs to communicate with two servers that are residing at different port numbers then an extended syntax may be used with the EPICS_CA_ADDR_LIST environment variable. Each host name or IP address in the EPICS_CA_ADDR_LIST may be immediately followed by a colon and an IP port number without intervening whitespace. Entries that do not specify a port number will default to EPICS_CA_SERVER_PORT.
C shell	setenv EPICS_CA_ADDR_LIST "1.2.3.255 8.9.10.255:10000"
N.N.N.N:P is the IP_address:port_number
Yong
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Jameson Graef Rollins
Sent: Tuesday, July 09, 2013 9:07 PM
To: [email protected]
Subject: Re: multiple servers on the same (loopback) interface
On Tue, Jul 09 2013, Jameson Graef Rollins <[email protected]> wrote:
> Hey, folks.  I'm trying to run multiple IOCs on the same host and
> network interface and I'm looking for tips to help get it working
> cleanly.  I'm aware of some of the issues of servers sharing the same
> interface [0].  However, I assume there must be a way to support this
> situation, since I imagine it must be common.  But I'm having a lot of
> trouble getting it to work.
Someone offline has pointed me to an undocumented solution that seems to work fine, and I wanted to share it here for others that may be interested.
Apparently addresses specified in EPICS_CA_ADDR_LIST can include colon-separated port specifiers, i.e. N.N.N.N:PORT.  This means one can instantiate the servers on different ports:
EPICS_CAS_INTF_ADDR_LIST=localhost EPICS_CAS_SERVER_PORT=58900 ./test/testioc.py TEST0:
EPICS_CAS_INTF_ADDR_LIST=localhost EPICS_CAS_SERVER_PORT=58901 ./test/testioc.py TEST1:
and specify both to the client:
0$ EPICS_CA_ADDR_LIST='localhost:58900 localhost:58901' caget -t TEST0:FOO
0
0$ EPICS_CA_ADDR_LIST='localhost:58900 localhost:58901' caget -t TEST1:FOO
0
0$
The client therefore doesn't need to know which channels are at which port.  This also works for localhost, so dummy network interfaces aren't required.  This is a nice simple solution to the problem.
Unfortunately, it appears that this behavior (that ports can be specified in the CA_ADDR_LIST list) is undocumented.  At least I can't find reference to it in any of the CA documentation that I've found so far.  If anyone sees a problem with this method please let me know.
Thanks so much for everyone's suggestions.
jamie.
RE: multiple servers on the same (loopback) interface Jameson Graef Rollins
Re: multiple servers on the same (loopback) interface Jameson Graef Rollins
Prev: Re: Another strange CA observation Benjamin Franksen
Next: RE: multiple servers on the same (loopback) interface Jameson Graef Rollins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: multiple servers on the same (loopback) interface Jameson Graef Rollins
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
