1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: asyn+streamDevice hangs with synchronousLock:Yes
To: Brian McAllister <[email protected]>
Date: Mon, 8 Jul 2013 03:26:08 +0000
That is interesting.  When it is hung and you type
epicsMutexShowAll, 1
repeatedly, do you always see the same thing, i.e.
> ellCount(&mutexList) 117 ellCount(&freeList) 12
> epicsMutexId 0x894b988 source ../../asyn/asynDriver/asynManager.c line 1868
> epicsMutexId 0x89a2710 source ../../../src/libCom/osi/epicsMutex.cpp line 222
From: [email protected] [[email protected]] on behalf of Brian McAllister [[email protected]]
Sent: Sunday, July 07, 2013 11:46 AM
To: Mark Rivers
Cc: Dirk Zimoch; [email protected]
Subject: Re: asyn+streamDevice hangs with synchronousLock:Yes
>>> On 7/4/2013 at 6:38:42 -0000, Mark Rivers wrote:
  >> If you simplfy your problem to a single record does the problem go
  >> away?
No.
I ran it with one record.  Hung (with same mutex report) after less than
two hours.
- brian
Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
RE: asyn+streamDevice hangs with synchronousLock:Yes Mark Rivers
Prev: Re: catching python exception in pcaspy Xiaoqiang Wang
Next: Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
