1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Macros limited (edition ;-)
To: [email protected]
Cc: Touchard Dominique <[email protected]>
Date: Fri, 5 Jul 2013 10:39:43 -0500
Hi Dominique,
On 2013-07-05 Dominique Touchard wrote:
> It seems that the number of macros for template substitutions during IOC
> startup is limited to 100. Over, a segmentation fault stop the IOCs.
> Is this number correct? Is there any reason?
I was surprised but you're right, src/dbtools/dbLoadTemplate.y defines
VAR_MAX_VARS as 100 which sets a limit to the number of variables that
dbLoadTemplate() can handle.  It also defines VAR_MAX_VAR_STRING as 5000
setting the maximum size of the "variable=value,..." string which it
constructs to pass to dbLoadRecords().  In neither case though does it check
when the storage limit set by those macros gets exceeded, thus causing a
crash.  This is obviously unacceptable and needs to be fixed in Base.
To get around this limit for a particular application you could do the
template expansion on the host at build time using the msi (Macro
Substitution and Include) program which is distributed as an EPICS extension.
You can also increase the above values in your source code and rebuild base,
which might be a simpler fix in some circumstances.
I have filed a bug-report for this issue.  If someone feels inclined to look
at rewriting the dbLoadTemplate() code to remove these limitations please let
me know.
    https://bugs.launchpad.net/epics-base/+bug/1198234
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Macros limited (edition ;-) Touchard Dominique
Prev: Re: Reading binary file from sscan saveData Hovanes Egiyan
Next: Re: Development with EPICS and CSS marcus . michalsky
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Macros limited (edition ;-) Touchard Dominique
Next: Development with EPICS and CSS Ganesh Jangir
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
