1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Reading binary file from sscan saveData
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Fri, 05 Jul 2013 11:08:23 -0400
"mdautils" works fine for us.
Hovanes.
On 07/03/2013 10:18 AM, Tim Mooney wrote:
There is a collection of C programs to read and translate
MDA files in the synApps utils directory, and also here:
http://www.aps.anl.gov/bcda/mdautils/
There are python programs for reading and translating MDA files in
the synApps utils directory.  Utils is not published separately from
synApps, but you can browse the repository here:
https://subversion.xray.aps.anl.gov/synApps/utils/trunk/mdaPythonUtils/
There is also a wxPython program to display MDA files in the utils
directory:
https://subversion.xray.aps.anl.gov/synApps/utils/trunk/mdaExplorer/
There is IDL iTools-based software to display MDA files here:
http://cars.uchicago.edu/software/idl/epics_sscan_display.html
There is an IDL program for displaying scan data both from data files,
and from running sscan records.  It's described here, but the releases
on this page are very old:
http://www.aps.anl.gov/bcda/dataVis/scanSee.html
There is a program called "dview" for displaying MDA files, written by
Dohn Arms (the mdautils author).  I don't know if there is a published
version of the program.
Tim Mooney
----- Original Message -----
To: [email protected]
Sent: Wednesday, July 3, 2013 8:27:41 AM
Subject: Reading binary file from sscan saveData
we would like to use "sscan" EPICS record for some automated data
taking
using motorized stages. Everything seems to work fine so far. The
result
of the standard setup for "sscan" are binary files which are written
using a library
contained in the "sscan" record.  Also there is a description of the
format of these files.
But before doing anything on our own with these binary files, we
would
like to know:
o Is there an example (or a library) of how to read these files using
a
code written C/C++?
o Is there already an application that can read these data and create
graphical
presentations of the data.
Thanks in advance,
      Hovanes Egiyan.
Re: Reading binary file from sscan saveData Tim Mooney
Prev: Development with EPICS and CSS Ganesh Jangir
Next: Re: Macros limited (edition ;-) Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Reading binary file from sscan saveData Tim Mooney
Next: Apologies for mailman issue Andrew Johnson
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
