1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: asyn+streamDevice hangs with synchronousLock:Yes
To: Brian McAllister <[email protected]>
Date: Tue, 2 Jul 2013 18:27:16 +0000
When it is hung please do
epicsMutexShowAll 1
I think you have probably run into a deadlock, which can happen when multiple mutexes are taken/released in the wrong order.
If you simplfy your problem to a single record does the problem go away?
I am not an expert on using I/O Intr scanned records with StreamDevice, particularly multiple records on the same port.  Dirk may be able to help with this.
From: [email protected] [[email protected]] on behalf of Brian McAllister [[email protected]]
Sent: Tuesday, July 02, 2013 1:23 PM
To: Mark Rivers
Cc: [email protected]
Subject: Re: asyn+streamDevice hangs with synchronousLock:Yes
What does it mean if synchronousLock is permanently "Yes" ?
I see it's a mutex and that it's used in many places.  Is there any way to
find out where it is being locked/not unlocked ?
- brian
Re: asyn+streamDevice hangs with synchronousLock:Yes Dirk Zimoch
RE: asyn+streamDevice hangs with synchronousLock:Yes Mark Rivers
Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
Prev: Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
Next: caLab Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: asyn+streamDevice hangs with synchronousLock:Yes Dirk Zimoch
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
