On 29.06.2013 19:09, Andrew Johnson wrote:
We don't know at compile-time that you aren't planning to load the xyz module from some other .munch file or lib.so shared library (and although I don't particularly recommend it, that is something which Dirk Zimoch wants to be able to do). Now I could conceive of some kind of optional way to test your binary for completeness(which Dirk would not use), but for VxWorks that would require that we know all of the symbols that your specific VxWorks boot image provides since those are symbols which are supposed to be undefined in your .munch file.
Hi Andrew,
That is not exactly what I want to be able to do. I want to be able to
build software modular. That still means that the code and the entry in
the dbd must match. For example if the dbd mentions registrar(xyz), that
registrar should be in the code.
I want to be able to define device support for a record type in a
different module than the record itself. I.e. to be able to have the dbd
entry for devAiXXX together with the code. But without having to include
the aiRecord.dbd into my dbd file. Exactly because my module does not
provide the aiRecord code.
Thus I also prefer a system that warns me if I define something in the
dbd file that is missing in the code. I simply do not want to put all
dependencies into the dbd file, because that forces me to build
monolithic code.
Dirk
- registerRecordDevice... crashes IOC during startup Benjamin Franksen
- Re: registerRecordDevice... crashes IOC during startup Andrew Johnson
Support for Amp Tek X-123 David Reid
Re: registerRecordDevice... crashes IOC during startup Dirk Zimoch
<2013>
Re: registerRecordDevice... crashes IOC during startup Ron Sluiter
<2013>
