Hi Jamie,
On my Mac OS with EPICS 3.14.12.3, the following command works,
$ EPICS_CAS_INTF_ADDR_LIST="localhost" python dummy.py
Best
Xiaoqiang
On Jun 28, 2013, at 7:26 PM, Jameson Graef Rollins <[email protected]> wrote:
> Hi, folks. I have a question about the caServer as provided by the
> pcaspy python package. I hope this is an appropriate place to ask.
> I'm wondering how to specify the network that the caServer binds to. If
> I run the example/dummy.py server script that comes with the source, it
> works fine if I have an active outward-facing network interface.
> However, if I'm offline I get the following error:
> servo:~/src/pcaspy/git 0$ python ./example/dummy.py
> filename="../../../../src/cas/io/bsdSocket/casDGIntfIO.cc" line number=121
> server isnt attached to a network - unable to continue
> filename="../../../../src/cas/io/bsdSocket/caServerIO.cc" line number=131
> Attempt to set server's IP address/port failed unable to attach any interface
> filename="../../../../src/cas/generic/caServerI.cc" line number=62
> server isnt attached to a network - CA server internals init unable to continue
> terminate called after throwing an instance of 'int'
> Aborted
> Presumably it's trying to bind to an interface that doesn't exist or is
> not configured. I would like to specify that the server just bind to
> the loopback interface. Does anyone know accomplish this?
> Any advice would be great appreciated. Thanks!
> jamie.
- Re: specifying network interface with pcaspy caServer Jameson Graef Rollins
- specifying network interface with pcaspy caServer Jameson Graef Rollins
registerRecordDevice... crashes IOC during startup Benjamin Franksen
<2013>
<2013>
