Subject: |
specifying network interface with pcaspy caServer |
Jameson Graef Rollins <[email protected]> |
To: |
Tech Talk <[email protected]> |
Date: |
Fri, 28 Jun 2013 10:26:52 -0700 |
Hi, folks. I have a question about the caServer as provided by the
pcaspy python package. I hope this is an appropriate place to ask.
I'm wondering how to specify the network that the caServer binds to. If
I run the example/dummy.py server script that comes with the source, it
works fine if I have an active outward-facing network interface.
However, if I'm offline I get the following error:
servo:~/src/pcaspy/git 0$ python ./example/dummy.py
filename="../../../../src/cas/io/bsdSocket/casDGIntfIO.cc" line number=121
server isnt attached to a network - unable to continue
filename="../../../../src/cas/io/bsdSocket/caServerIO.cc" line number=131
Attempt to set server's IP address/port failed unable to attach any interface
filename="../../../../src/cas/generic/caServerI.cc" line number=62
server isnt attached to a network - CA server internals init unable to continue
terminate called after throwing an instance of 'int'
Aborted
Presumably it's trying to bind to an interface that doesn't exist or is
not configured. I would like to specify that the server just bind to
the loopback interface. Does anyone know accomplish this?
Any advice would be great appreciated. Thanks!
jamie.
pgpxAywbmm437.pgp
Description: PGP signature
- Re: specifying network interface with pcaspy caServer Xiaoqiang Wang
RE: querying for sets of pvs in archived data pthomas
Re: Problem in errlogRemoveListener Andrew Johnson
<2013>
RE: Sub-arrays Dalesio, Leo
<2013>
