1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: caget apparent timeout
To: D Peter Siddons <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 27 Jun 2013 23:21:41 +0000
That sounds like a problem I had recently.  I tracked it down to a misconfigured DNS server that was not resolving the reverse DNS lookup, i.e. IP number to IP name.
From: [email protected] [[email protected]] on behalf of D Peter Siddons [[email protected]]
Sent: Thursday, June 27, 2013 4:14 PM
To: [email protected]
Subject: Re: caget apparent timeout
Hi Andrew,
EPICS 3.14.12.2
Ubuntu 12.04.2
Pete.
On 06/27/2013 01:13 PM, Andrew Johnson wrote:
> Hi Peter,
> On 2013-06-27 D Peter Siddons wrote:
>> Occasionally, I need to check or change a PV, for which I use the
>> caget and caput command-line utilities. The operation (put or get) is
>> executed immediately, but then the PC waits for several seconds before
>> the cursor is returned. Does anyone know what is causing this? It feels
>> like a network timeout, but all I have is a PC and an IOC with a
>> crossover cable between. Anyone know the fix?
> What version of EPICS were your caget/caput programs built against, and what
> is the Linux version they're running on?  We used to see delays like this at
> process shutdown while the atexit() routines were being run, but they were
> cleaned up quite a few releases ago.
> - Andrew
D. Peter Siddons
Detector Development Group Leader
Bldg. 535B
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: [email protected]
Phone: (631) 344-2738
RE: caget apparent timeout Mark Rivers
caget apparent timeout D Peter Siddons
Re: caget apparent timeout Andrew Johnson
Re: caget apparent timeout D Peter Siddons
Prev: Re: caget apparent timeout D Peter Siddons
Next: RE: caget apparent timeout Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
