1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: caget apparent timeout
To: EPICS <[email protected]>
Date: Thu, 27 Jun 2013 10:43:29 -0400
Hi all,
I have a problem which seems to crop up occasionally, depending on the setup, but quite often. I have a PC running MEDM screens connected to a remote IOC by a crossover ethernet cable. The MEDM apps all run fine. Occasionally, I need to check or change a PV, for which I use the caget and caput command-line utilities. The operation (put or get) is executed immediately, but then the PC waits for several seconds before the cursor is returned. Does anyone know what is causing this? It feels like a network timeout, but all I have is a PC and an IOC with a crossover cable between. Anyone know the fix?
Pete.
D. Peter Siddons
Detector Development Group Leader
Bldg. 535B
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: [email protected]
Phone: (631) 344-2738
RE: caget apparent timeout Hill, Jeff
Re: caget apparent timeout Andrew Johnson
Prev: RE: ca_get and ca_put triggered by monitors? Hill, Jeff
Next: RE: caget apparent timeout Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
