1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: caget can't connect to soft ioc on host with multiple NICs
Date: Thu, 27 Jun 2013 10:33:50 -0400
>>> On 6/27/2013 at 7:18:58 -0000, Mark Rivers wrote:
  > My next guess is that there may be a firewall running on your
  > system. Is iptables running?
You are correct.  Inbound connections on eth1 were blocked and I had eth0
restricted to SSH/tcp while I was setting up the machine.  Normally I allow
all traffic from the local subnet.
Opening eth0 (or eth1) fixes the problem.  If I open both, then I need to
set EPICS_CA_AUTO_ADDR_LIST=NO and use EPICS_CA_ADDR_LIST.
I still don't understand why it didn't work from the local host.  iptables
accepts all traffic from the loopback.  Why doesn't that work for CA ?
- brian
Re: caget can't connect to soft ioc on host with multiple NICs Andrew Johnson
Re: caget can't connect to soft ioc on host with multiple NICs Dirk Zimoch
RE: caget can't connect to soft ioc on host with multiple NICs Mark Rivers
Prev: Re: ca_get and ca_put triggered by monitors? J. Lewis Muir
Next: RE: ca_get and ca_put triggered by monitors? Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: caget can't connect to soft ioc on host with multiple NICs Mark Rivers
Next: Re: caget can't connect to soft ioc on host with multiple NICs Andrew Johnson
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
