1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: ca_get and ca_put triggered by monitors?
To: EPICS <[email protected]>
Date: Thu, 27 Jun 2013 15:16:04 +0200
Hi all,
I have an application which needs to read or write EPICS data whenever something interesting happens with other EPICS data. The naive way would be to do ca_get and/or ca_put inside a monitor callback function. But as far as I remember, this is forbidden.
Is this (still) true? I cannot find anything about this in the Channel Access Reference Manual.
If it is not (yet) possible, can this be implemented in a future release of the channel access library? I think it is a common use case to "do something when something else happened".
What is the best practice to do monitor triggered channel access at the moment?
One way I can imagine is to setup a different thread blocking on an event semaphore and release that semaphore from within the monitor callback. But this involves thread save programming with all its complications.
Dirk
Re: ca_get and ca_put triggered by monitors? J. Lewis Muir
RE: ca_get and ca_put triggered by monitors? Hill, Jeff
Prev: RE: caget can't connect to soft ioc on host with multiple NICs Mark Rivers
Next: Re: ca_get and ca_put triggered by monitors? J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: caget can't connect to soft ioc on host with multiple NICs Dirk Zimoch
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
