1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Record Processing
To: Zenon Szalata <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 27 Jun 2013 05:59:55 +0000
It does not make sense that it is writing 0.
Does your driver implement readInt32 and does it get called during iocInit for that record? If so what does it return as the status function return value?
Sent: Wednesday, June 26, 2013 12:01 AM
To: Mark Rivers; [email protected]
Subject: Record Processing
Hi Mark,
I have a simple longout record
record( longout, "$(P):LO:DEBUG-$(M):MFUNC"){
   field( DESC, "Modbus Func:")
   field( DTYP, "asynInt32")
   field( OUT,  "@asyn(DEBUG,0,1)LO_MFUNC")
   field( VAL,  "3")
   field( PINI, "YES")
It is a part of an IOC which uses asynPortDriver class driver.  I put a
print statement in writeInt32 function and at IOC initialization time it
prints that the value to write is 0.
Then at the end of st.cmd script I have put a
dbpf <record name>.PROC 1
for this record and this time the value to write is 3.  Why is the
record writing 0 at IOC initialize time?
I am not sure if this is a basic EPICS or asyn issue, so I thought I ask
you.
Zen
Re: Record Processing Zenon Szalata
Prev: Re: caget can't connect to soft ioc on host with multiple NICs Hu, Yong
Next: RE: caget can't connect to soft ioc on host with multiple NICs Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Record Processing Zenon Szalata
Next: Re: Record Processing Zenon Szalata
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
