1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem in errlogRemoveListener
To: Michael Abbott <[email protected]>
Cc: [email protected]
Date: Mon, 24 Jun 2013 12:16:10 -0500
Hi Michael,
On 2013-06-24 Michael Abbott wrote:
> On Mon, 24 Jun 2013, Andrew Johnson wrote:
> > This is a C API, C doesn't have closures
> Of course C has closures, they just require a little cooperation from the
> called function part.  A closure in C is a function taking at least one
> void* parameter together with a void* value to pass to it.
The void* parameter is what we've always regarded as a context pointer for
the function.  The storage for that data has to be managed by the programmer
though, so while it performs the same job as a closure it isn't a real one.
http://en.wikipedia.org/wiki/Closure_(computer_science) says:
  "The idiom is similar to closures in functionality, but not in syntax."
> In truth a C++ closure is exactly the same thing, only in disguise.
C++11 has closures which it calls lambda-expressions; they look very useful,
but do move the language even more in the direction of line-noise IMHO.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: Problem in errlogRemoveListener Benjamin Franksen
Re: Problem in errlogRemoveListener Andrew Johnson
Re: Problem in errlogRemoveListener Michael Abbott
Prev: Re: PyEpics speed Daron Chabot
Next: cannot start test application Costello, Charles C.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Problem in errlogRemoveListener Michael Abbott
Next: Re: Problem in errlogRemoveListener Benjamin Franksen
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
