The errlog facility provides errlogAddListener, and errlogRemoveListener.
Unfortunately, the latter is broken, as there is no way to specify the
listener's private data. So if I have two listeners which differ only in their
private data (such as when using two instances of feller), then I can only
remove them all at once, not each one separately.
The attached patch file rectifies that by adding an errlogRemoveSingleListener
function to the API that allows to remove single instances.
Cheers
Ben Franksen
() ascii ribbon campaign - against html e-mail
/\ www.asciiribbon.org - against proprietary attachm€nts
Fri Jun 21 11:15:25 CEST 2013 [email protected]
* FIX: libCom/error: added errlogRemoveSingleListener
diff -rN -u old-3-14-12-2-1/src/libCom/error/errlog.c new-3-14-12-2-1/src/libCom/error/errlog.c
--- old-3-14-12-2-1/src/libCom/error/errlog.c 2013-06-21 11:17:28.886150560 +0200
+++ new-3-14-12-2-1/src/libCom/error/errlog.c 2013-06-21 11:17:30.449710101 +0200
@@ -324,6 +324,28 @@
+epicsShareFunc void epicsShareAPI errlogRemoveSingleListener(
+ errlogListener listener, void *pPrivate)
+ listenerNode *plistenerNode;
+ errlogInit(0);
+ if (!pvtData.atExit) epicsMutexMustLock(pvtData.listenerLock);
+ plistenerNode = (listenerNode *)ellFirst(&pvtData.listenerList);
+ while (plistenerNode) {
+ if (plistenerNode->listener==listener && plistenerNode->pPrivate==pPrivate) {
+ ellDelete(&pvtData.listenerList, &plistenerNode->node);
+ free((void *)plistenerNode);
+ break;
+ plistenerNode = (listenerNode *)ellNext(&plistenerNode->node);
+ if (!pvtData.atExit) epicsMutexUnlock(pvtData.listenerLock);
+ if (!plistenerNode) {
+ fprintf(stderr, "errlogRemoveListener did not find listener\n");
epicsShareFunc int epicsShareAPI eltc(int yesno)
errlogInit(0);
diff -rN -u old-3-14-12-2-1/src/libCom/error/errlog.h new-3-14-12-2-1/src/libCom/error/errlog.h
--- old-3-14-12-2-1/src/libCom/error/errlog.h 2013-06-21 11:17:28.882151686 +0200
+++ new-3-14-12-2-1/src/libCom/error/errlog.h 2013-06-21 11:17:30.449710101 +0200
@@ -58,6 +58,8 @@
errlogListener listener, void *pPrivate);
epicsShareFunc void epicsShareAPI errlogRemoveListener(
errlogListener listener);
+ errlogListener listener, void *pPrivate);
epicsShareFunc int epicsShareAPI eltc(int yesno);
epicsShareFunc int epicsShareAPI errlogInit(int bufsize);
signature.asc
Description: This is a digitally signed message part.
- Re: Problem in errlogRemoveListener Benjamin Franksen
Re: help setting up XY table control with EPICS StreamerClass Christian Pauly
<2013>
Scientific programmer II position available at the Joint Astronomy Centre Maren Purves
<2013>
