1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS device disconnects and reconnects
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 18 Jun 2013 13:21:41 +0200
Hi Mark,
I have a comments and a question on this topic:
A) From my experience, there are three possible options to handle the
reconnect/reboot situation, that all have valid use cases:
1. DB is dominant, takes value from DOL or AutoSaveRestore, and writes
to the device.
2. DB is recessive, reads value from device.
3. DB is minimal invasive, takes value from DOL or AutoSaveRestore, and
does not interact with the device.
I am not sure how a single bit could encode these three options.
B) The PINI field menu currently has 6 options:
NO, YES, RUN, RUNNING, PAUSE, PAUSED.
What is the intended behavior for the four options that were not yet
mentioned in this thread?
~Ralph
RE: EPICS device disconnects and reconnects Mark Rivers
Re: EPICS device disconnects and reconnects Kate Feng
Re: EPICS device disconnects and reconnects Jason Abernathy
Re: EPICS device disconnects and reconnects Pearson, Matthew R.
Prev: Re: EPICS device disconnects and reconnects Pearson, Matthew R.
Next: RE: EPICS device disconnects and reconnects Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
