1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS device disconnects and reconnects
To: [email protected]
Date: Mon, 17 Jun 2013 10:02:19 -0500
Hi Mark,
On 2013-06-15 Mark Rivers wrote:
> It turns out that the acquire parameter, ADAcquire was being set to 0 in
> the constructor for the ADBase base class.  But the busy record still has
> STAT=UDF, SEVR=INVALID. Further investigation shows that this is the case
> for all record types if the record has never processed.
It is possible to set STAT and SEVR to NO_ALARM (or 0) in your .db file if
you don't want a record to be in an alarm state and you can't set PINI=YES.
- Andrew
What would the effect on the NSA be if everybody put in their
signature lines stuff like "the bomb goes off tonight"?
EPICS device disconnects and reconnects Mark Rivers
Re: EPICS device disconnects and reconnects feng
RE: EPICS device disconnects and reconnects Mark Rivers
Prev: 转发: Epics ioc share from Phoenix Contact chenyuhui
Next: Re: 转发: Epics ioc share from Phoenix Contact Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: EPICS device disconnects and reconnects Mark Rivers
Next: Re: EPICS device disconnects and reconnects Bruce Hill
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
