1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: analog output record - constant DOL
To: [email protected]
Date: Fri, 14 Jun 2013 10:30:41 -0500
Hi Rolf,
On 2013-06-14 Rolf Keitel wrote:
> I am setting  DOL to the desired constant value and OMSL=closed_loop and
> everything seems to work as desired.
> When I do a caput to one of these ao records, however, the record
> outputs from this moment the value received from the caput and ignores
> the DOL value.
> This seems counter-intuitive to me. I had expected that in closed_loop
> mode, the VAL field would be *always* obtained from the DOL link.
> Does anyone remember what the rationale is for treating a constant link
> differently from a db or ca link?
Constant links are only ever read once, at record initialization time, and
this is true for all link fields of all record types.  I assume this was done
to avoid having to call strtod() or its equivalent every time the IOC reads
the link, which could be a significant drag on performance for something like
a CALC or SEQ record which have many links that are often constants.  A link
field that has not been set is currently a constant link too.
There is an opportunity to reconsider this design in some work I'm doing for
3.15/3.16 and v4 (link support), but I would still want to avoid converting
the value from its string every time the link gets read.  The ability to
specify string and array constants also comes to mind as desirable, but don't
hold your breath waiting.
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
analog output record - constant DOL Rolf Keitel
Prev: Re: GUI Control System Options Kasemir, Kay
Next: Re: Support for TDK Lambda PS? Burkhard Kolb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: analog output record - constant DOL Rolf Keitel
Next: Re: analog output record - constant DOL Rolf Keitel
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
