Hi, I want to know more about VAL field of PV in asynDriver. as i understand of i defiend VAL field to some value in DB file then it sould be written on output. I have develop my own driver to write value on serial port using asyn driver. and it is working fine. if i write some value . it is output on port. But if i write VAL field in DB file. it is not writting that value to the output The DB file content is as below record (longout,"TEST:VAL") { field(DESC, "New Variable") field(DTYP, "asynUInt32Digital") field(HOPR, "255") field(LOPR, "0") field(OUT, "@asynMask(port, 0,255) setportval") field(VAL, "7") } Even if i am tring to read same PV it gives value 0. $ caget TEST:VAL TEST:VAL 0 Actually i put VAL field for giving fixed output on serial port at the time of IOC start bootup. Thanks
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
