1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: calc DTYP
To: "Pearson, Matthew R." <[email protected]>
Date: Thu, 13 Jun 2013 15:06:25 -0400
Oh, never mind.  I misunderstood. That is just part of the error message.
Sorry
James
On Thu, Jun 13, 2013 at 3:05 PM, James F Ross <[email protected]> wrote:
It looks like there might be a space after PV: in the variable according to what you copied from the error message (PV: BL7:Det:PMT001:Stat.DTYP).  Maybe check where the record is in the DB file to make sure there isn't a typo?
James
On Thu, Jun 13, 2013 at 3:00 PM, Pearson, Matthew R. <[email protected]> wrote:
I'm seeing this error on my IOC shell:
epics> Illegal choice PV: BL7:Det:PMT001:Stat.DTYP error detected in routine: dbFastLinkConv(cvt_device_st)
where:
epics> dbpr BL7:Det:PMT001:Stat,2
A: 0                ACKS: NO_ALARM      ACKT: YES           ADEL: 0
ASG:                B: 0                BKPT: 00            C: 1
CALC: (A!=0)||(B!=0)||(C!=1)            D: 0                DESC: HV Base Status
DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
DTYP: <nil>         E: 0                EGU:                EVNT: 0
F: 0                FLNK:CONSTANT 0     G: 0                H: 0
HHSV: NO_ALARM      HIGH: 0             HIHI: 0             HOPR: 0
HSV: NO_ALARM       HYST: 0             I: 0
INPA:CA_LINK BL7:Det:PMT001:Volt.STAT CP NMS
INPB:CA_LINK BL7:Det:PMT001:Curr.STAT CP NMS
INPC:CA_LINK BL7:Det:Asyn.CNCT CP NMS   INPD:CONSTANT       INPE:CONSTANT
INPF:CONSTANT       INPG:CONSTANT       INPH:CONSTANT       INPI:CONSTANT
INPJ:CONSTANT       INPK:CONSTANT       INPL:CONSTANT       J: 0
K: 0                L: 0                LCNT: 0             LLSV: NO_ALARM
LOLO: 0             LOPR: 0             LOW: 0              LSV: NO_ALARM
MDEL: 0             NAME: BL7:Det:PMT001:Stat               NSEV: NO_ALARM
NSTA: NO_ALARM      PACT: 0             PHAS: 0             PINI: NO
PREC: 0             PRIO: LOW           PUTF: 0             RPRO: 0
SCAN: Passive       SDIS:CONSTANT       SEVR: NO_ALARM      STAT: NO_ALARM
TIME: 2013-06-13 12:11:11.138031191     TPRO: 0             TSE: 0
TSEL:CONSTANT       UDF: 0              VAL: 0
So, my calc record doesn't have any registered device support, which I think is correct because there is no device support for the calc record (?)
I'm wondering why the error is printed, or even if it should be. It's printed whenever I try to read DTYP over channel access, like:
[mkp@DASDEV1 ~]$ caget BL7:Det:PMT001:Stat.DTYP
CA.Client.Exception...............................................
    Warning: "Channel read request failed"
    Context: "op=0, channel=BL7:Det:PMT001:Stat.DTYP, type=DBR_TIME_STRING, count=1, ctx="read failed""
    Source File: ../getCopy.cpp line 92
    Current Time: Thu Jun 13 2013 13:46:12.759397671
Read operation timed out: some PV data was not read.
Shouldn't it just return 0, or None, rather than returning an error?
I only noticed it because I have a script that was reading the DTYP field on a set of records. Normally, I guess it doesn't matter since reading DTYP on a calc record doesn't mean much.
Cheers,
Matt
calc DTYP Pearson, Matthew R.
Re: calc DTYP James F Ross
Prev: Re: calc DTYP James F Ross
Next: Horner PLC %T readout Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
