Just a side note. Back in 2010, our E5810A devices (firmware rev. A.01.09) failed a network scan. I contacted Agilent and they said they were aware of the issue and had no immediate plans to address it. The problem was that the vxWorks debugger was running in that firmware revision. Perhaps that was corrected in the E5810B version.
Tony
I am using both. Both work reasonably well. The Agilent unit is a
bit more robust, since the ICS device is more likely to be adversely
affected by computer security scans. If you put the LAN-GPIB
gateway on a private sub-net, then they both will do well. The
Agilent is significantly more pricey.
Zen
On 06/13/13 01:01, BOGARD Daniel wrote:
Hi, I plan to do GPIB with
asyn using a LAN/GPIB gateway and EPICS running on a Linux
PC. What is the best choice
for the gateway between Agilent E5810B and ICS8065? Thanks in advance. Daniel Bogard Accelerators Control
engineer . Saclay(France) [email protected]
-- Anthony Pietryla Controls Engineer Advanced Photon Source Argonne National Laboratory
Phone: 630-252-7430 Fax: 630-252-6123
- LAN GPIB BOGARD Daniel
- Re: LAN GPIB Zenon Szalata
Re: SEQ keep PV value during seq-init Benjamin Franksen
<2013>
Why is RELEASE now included in CONFIG_INSTALLS ? Brian McAllister
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
