1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Changing SCAN field in many records
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Thu, 13 Jun 2013 08:36:19 +0200
On 06/07/2013 04:17 PM, Tim Mooney wrote:
Hi Hinko,
I would do this with a seq record.
Dear Tim,
Thanks for the suggestion. Will give it a go.
Best Regards,
Hinko
Tim
----- Original Message -----
To: [email protected]
Sent: Friday, June 7, 2013 1:56:12 AM
Subject: Changing SCAN field in many records
We would like to set a SCAN field on several lower level BO records,
at
the same time, and the value of these SCAN fields should reflect the
value of the single higher level record SCAN field.
For the control of these lower level SCAN fields another, higher
level
record, would be used. If a user wishes to set individual lower level
record SCAN fields, she is allowed. OTOH, when changing the SCAN of
the
higher level record, ALL lower lever BO records would get their SCAN
field set too.
Is it possible to get this done without using a sequencer?
TIA and HAND,
Hinko
Re: Changing SCAN field in many records Tim Mooney
Prev: RE: Adding error msgs to dbAccess.c Allison, Stephanie
Next: Re: Changing SCAN field in many records Hinko Kočevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Changing SCAN field in many records Tim Mooney
Next: new synApps module versions Tim Mooney
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
