Folks,
I've made the changes to asyn to support a new command:
asynSetTraceInfoMask
The mask is defined with these bits:
/* traceInfo mask definitions*/
#define ASYN_TRACEINFO_TIME 0x0001
#define ASYN_TRACEINFO_PORT 0x0002
#define ASYN_TRACEINFO_SOURCE 0x0004
ASYN_TRACEINFO_TIME prints what has always been printed, the date and time of the message.
ASYN_TRACEINFO_PORT prints [port,addr,reason], where port is the port name, addr is the asyn address, and reason is pasynUser->reason. Those are the 3 pieces of "addressing" information in asyn.
ASYN_TRACEINFO_SOURCE prints [__FILE__,__LINE__] where the asynPrint statement occurs.
Here is an example of an asynPrint output when all 3 bits are set:
2013/06/11 17:23:51.198 [testAPD,-1,14] [../../asyn/devEpics/devAsynFloat64.c,396] testAPD:scope1:MinValue_RBV devAsynFloat64::getCallbackValue from ringBuffer value=-0.037271
I have modified the asynRecord to support the new ASYN_TRACE_WARNING, and all of the new ASYN_TRACEINFO bits. I've attached a screen shot.
Everything is committed to SVN.
Let me know of any suggestions or problems.
Cheers,
-----Original Message-----
Sent: Tuesday, June 11, 2013 1:26 PM
To: Mark Rivers
Cc: '[email protected]'; [email protected]
Subject: Re: asynPrint to print asyn port name
On Jun 11, 2013, at 11:10 AM, Mark Rivers <[email protected]> wrote:
> Folks,
> Ulrik, thanks for sending that.
> I've thought about it some more, and I don't think that adding more bits to traceIOMask is the best way to handle this. traceIOMask is supposed to only apply to asynPrintIO calls, but these bits would also apply to asynPrint calls. I think we should make a new mask, asynTraceInfo.
> @@ -185,6 +186,8 @@
> #define ASYN_TRACEINFO_LINE 0x0004
Agreed.
> These options would print the time (enabled by default for backwards compatibility), the port name, and the file/line number in the source code. I think that can only work on platforms that implement the calls as macros, not as function calls, but that is actually most platforms.
You're referring to the varargs macro support, right? Are there any platforms that are neither _STDC_VERSION__>=199901L nor __GNUC__? I guess it's just too bad for them. Perhaps there should be a '#warning' in the asynDriver.h conditional for these platforms so developers are informed of why they're not seeing PORT/FILE/LINE information in their ASYN diagnostic messages.
> I would then add new shell command just like asynSetTraceMask, asynSetTraceIOMask
> asynSetTraceInfoMask port,addr,infoMask
> Thoughts?
The additional functionality is separate from the exiting TRACE and TRACEIO masks so it makes sense to have them broken out as separate masks.
Eric Norum
[email protected]
Description: asynRecord.png
- asynPrint to print asyn port name ulrik.pedersen
- RE: asynPrint to print asyn port name Mark Rivers
- Re: asynPrint to print asyn port name Mark Davis
- RE: asynPrint to print asyn port name ulrik.pedersen
RE: StreamDevice protocol file for Televac MM200 VGC Mohan Ramanathan
CSS plugin sources James F Ross
<2013>
Re: asynPrint to print asyn port name Bruce Hill
Help with CAJ installation.. Park, Young Soo
<2013>
