1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: PV name change and autosave
To: Emmanuel Mayssat <[email protected]>
Date: Fri, 07 Jun 2013 16:34:24 -0500
The most common place for lines of that time is the auto_settings.req
file.  There is an example in the synApps xxx module:
https://subversion.xray.aps.anl.gov/synApps/xxx/trunk/iocBoot/iocvxWorks/auto_settings.req
Kevin
On 6/7/13 4:22 PM, Emmanuel Mayssat wrote:
> Date: Fri, 7 Jun 2013 14:47:11 -0500
> From: [email protected]
> Normally, I just include a line of the form
>     file <request file> <macro definitions>
> for each database whose PVs I want autosaved.
> I am not sure I understand.
> where do you include that line?
> Do you have a pointer on some docs or example?
> E
RE: PV name change and autosave Emmanuel Mayssat
Re: PV name change and autosave Tim Mooney
Prev: Re: PV name change and autosave Pete Jemian
Next: Re: PV name change and autosave Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: PV name change and autosave Emmanuel Mayssat
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
