1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Issue with QuadEm/AreaDetector makefile...
Date: Thu, 6 Jun 2013 08:42:02 +1000
Hi everyone...
I am trying to build an IOC to use both QuadEm to support an AH401B picoammeter and a ProSilica camera using AreaDetector, and I’ve run into an issue with my Makefile in my IOCxxApp/src directory.
My make looks like this:
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
# Build the IOC application
PROD_IOC = SR08ID01IOC43
# SR08ID01IOC43.dbd will be created and installed
DBD += SR08ID01IOC43.dbd
# SR08ID01IOC43.dbd will be made up from these files:
SR08ID01IOC43_DBD += base.dbd
SR08ID01IOC43_DBD += asyn.dbd
SR08ID01IOC43_DBD += drvIpac.dbd
SR08ID01IOC43_DBD += ipUnidigSupport.dbd
SR08ID01IOC43_DBD += drvAPS_EM.dbd
SR08ID01IOC43_DBD += drvAHxxx.dbd
SR08ID01IOC43_DBD += quadEMTestApp.dbd
SR08ID01IOC43_DBD += drvAsynIPPort.dbd
SR08ID01IOC43_DBD += quadEMTestAppVx.dbd
SR08ID01IOC43_DBD += calcSupport.dbd
SR08ID01IOC43_DBD += asSupport.dbd
SR08ID01IOC43_DBD += busySupport.dbd
SR08ID01IOC43_DBD += sscanSupport.dbd
SR08ID01IOC43_DBD += ADSupport.dbd
SR08ID01IOC43_DBD += NDPluginSupport.dbd
SR08ID01IOC43_DBD += prosilicaApp.dbd
SR08ID01IOC43_DBD += prosilicaSupport.dbd
SR08ID01IOC43_INC += drvQuadEM.h
# SR08ID01IOC43_registerRecordDeviceDriver.cpp derives from SR08ID01IOC43.dbd
SR08ID01IOC43_SRCS += SR08ID01IOC43_registerRecordDeviceDriver.cpp
SR08ID01IOC43_SRCS_vxWorks += SR08ID01IOC43AppVx_registerRecordDeviceDriver.cpp
# Build the main IOC entry point on workstation OSs.
SR08ID01IOC43_SRCS_DEFAULT += SR08ID01IOC43Main.cpp
SR08ID01IOC43_SRCS_vxWorks += -nil-
# Add support from base/src/vxWorks if needed
SR08ID01IOC43_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
# Add all the support libraries needed by this IOC
# # Finally link to the EPICS Base libraries
SR08ID01IOC43_LIBS += autosave
SR08ID01IOC43_LIBS += quadEM
SR08ID01IOC43_LIBS_vxWorks += Ipac
SR08ID01IOC43_LIBS_vxWorks += ipUnidig
SR08ID01IOC43_LIBS += mca
SR08ID01IOC43_LIBS += seq pv
SR08ID01IOC43_LIBS += ADBase
SR08ID01IOC43_LIBS += prosilicaSrc
SR08ID01IOC43_LIBS += prosilicaApp
SR08ID01IOC43_LIBS += prosilicaSupport
SR08ID01IOC43_LIBS += sscan
SR08ID01IOC43_LIBS += busy
SR08ID01IOC43_LIBS += calc
SR08ID01IOC43_LIBS += asyn
SR08ID01IOC43_LIBS += $(EPICS_BASE_IOC_LIBS)
SR08ID01IOC43_LIBS_vxWorks += $(EPICS_BASE_IOC_LIBS)
include $(AREA_DETECTOR)/ADApp/commonDriverMakefile
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
And my output when I run my make is this:
src]$ make
perl /beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/base/bin/linux-x86/makeMakefile.pl O.linux-x86 ../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[1]: Entering directory `/beamline/perforce/Dev/SBS/3_Beamlines/3_10_SR08ID01_MIT/SR08ID01IOC43/SR08ID01IOC43App/src/O.linux-x86'
perl /beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/base/bin/linux-x86/makeIncludeDbd.pl base.dbd asyn.dbd drvIpac.dbd ipUnidigSupport.dbd drvAPS_EM.dbd drvAHxxx.dbd  quadEMTestApp.dbd drvAsynIPPort.dbd quadEMTestAppVx.dbd calcSupport.dbd asSupport.dbd busySupport.dbd  sscanSupport.dbd ADSupport.dbd NDPluginSupport.dbd prosilicaApp.dbd prosilicaSupport.dbd SR08ID01IOC43Include.dbd
echo "../O.Common/SR08ID01IOC43Include.dbd : ../Makefile" >> SR08ID01IOC43.dbd.d
Expanding dbd
Installing created dbd file ../../../dbd/SR08ID01IOC43.dbd
perl /beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/base/bin/linux-x86/registerRecordDeviceDriver.pl ../O.Common/SR08ID01IOC43.dbd SR08ID01IOC43_registerRecordDeviceDriver /beamline/perforce/Dev/SBS/3_Beamlines/3_10_SR08ID01_MIT/SR08ID01IOC43 > SR08ID01IOC43.tmp
mv SR08ID01IOC43.tmp SR08ID01IOC43_registerRecordDeviceDriver.cpp
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m32      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/base/include/os/Linux -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/base/include    -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/seq/include    -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/asyn/include    -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/calc/include    -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/sscan/include   -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/autosave/include/os/Linux -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/autosave/include    -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/busy/include    -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/quadEM/include    -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/ipac/include        -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/mca/include   -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/areaDetector/include/os/Linux -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/areaDetector/include         SR08ID01IOC43_registerRecordDeviceDriver.cpp
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m32      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/base/include/os/Linux -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/base/include    -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/seq/include    -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/asyn/include    -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/calc/include    -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/sscan/include   -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/autosave/include/os/Linux -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/autosave/include    -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/busy/include    -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/quadEM/include    -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/ipac/include        -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/mca/include   -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/areaDetector/include/os/Linux -I/beamline/perforce/Dev/SBS/3_Beamlines/Common/IOC_Support/areaDetector/include         ../SR08ID01IOC43Main.cpp
make[1]: *** No rule to make target `../../../lib/linux-x86/libprosilicaSrc.a', needed by `SR08ID01IOC43'.  Stop.
make[1]: Leaving directory `/beamline/perforce/Dev/SBS/3_Beamlines/3_10_SR08ID01_MIT/SR08ID01IOC43/SR08ID01IOC43App/src/O.linux-x86'
make: *** [install.linux-x86] Error 2
Any hints or tips would be greatly appreciated.
Thanks....
Dave Reid
Australian Synchrotron
SUPPLIERS: As of 1 January 2013, the Australian Synchrotron Company Ltd has changed its business name. However, the trading name will remain Australian Synchrotron.
Please address all quotations and invoices to: Synchrotron Light Source Australia Pty Ltd (SLSA), ABN: 18 159 468 256
RE: Issue with QuadEm/AreaDetector makefile... Mark Rivers
Prev: Re: Clarification on aliases and the .NAME field Andrew Johnson
Next: RE: Issue with QuadEm/AreaDetector makefile... Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: New EPICS support module "feller", release 0.1 Benjamin Franksen
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
