Hi Murali,
Your assumption is correct for CA servers that are real IOCs, the .NAME field should always give you the canonical record name when you're actually using an alias name. However a server that uses the PCAS could do whatever it wants with the PV name, it doesn't have to support the .FIELD syntax which the IOC uses.
- Andrew
Sent from my iPad
On Jun 5, 2013, at 1:20 PM, "Shankar, Murali" <[email protected]> wrote:
> It is my assumption that if I define a record like so
> record(ai, "pvname") {
> alias("aliasname")
> field(DESC , "This is a desc")
> Then, caget on pvname.NAME and caget on aliasname.NAME will give me the same result; i.e. pvname. That is, the .NAME field is used to hold the true name of the record and is the same when I refer to the record by using the realname or the aliasname.
> Would this be a correct assumption? One of our PCAS IOC's is using the .NAME field for something else and I'm trying to determine if this would be the right thing to do.
> Regards,
> Murali
- Clarification on aliases and the .NAME field Shankar, Murali
RE: seqLog obsolete / errlog filtering based on source Mark Rivers
Issue with QuadEm/AreaDetector makefile... David Reid
<2013>
seqLog obsolete / errlog filtering based on source Emmanuel Mayssat
<2013>
