1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: epicsqt 2.5.0 released
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 4 Jun 2013 17:49:58 +1000
Dear all,
A new version of the EPICS Qt Framework has been released and is available at https://sourceforge.net/projects/epicsqt/.
The default download and associated documentation is now for 2.5.0. Earlier versions are still available.
This version includes the following changes:
   - Addition of new QE widgets: QENumericEdit, QECheckBox, QERadioGroup.
   - Expand documentation (reference and guide).
   - Reduce startup time for embedded sub forms.
   - Display various information in 'Help->About' including macro substitutions, search paths, open files, version numbers of application, libraries and plugins.
   - Add persistence management. Configurations such as window layout can be saved and restored at any time including startup.
   - Add QEGui application logo.
   - QEGui executable is now named qegui.
   - Allow multiple gui files to be opened on startup.
   - QEGui has display scaling capability (-a startup parameter).
   - Add application wide user level passwords. Implemented in QEGui.
   - If QELogin widget is used in an application that does not use this feature, the QELogin widget maintains its own local passwords as before.
   - QERadionButton and QECheckBox now defaults to write "1" when checked and "0" when unchecked.
   - QEGui path list now uses : or ; (depending on platform) to sperate paths so spaces can be used within paths.
   - Bug fixes and minor enhancements. (See detailed log in release notes).
Enjoy,
Andrew Rhyder
SUPPLIERS: As of 1 January 2013, the Australian Synchrotron Company Ltd has changed its business name. However, the trading name will remain Australian Synchrotron.
Please address all quotations and invoices to: Synchrotron Light Source Australia Pty Ltd (SLSA), ABN: 18 159 468 256
Prev: Re: Questionable code in aToIPAddr Andrew Johnson
Next: Re:RE: IP330 modules question 문건영
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
