On 5/29/13 6:57 PM, Ned Arnold wrote:
> Hi Lewis -
> I had a similar problem on an RTEMS IOC when the NTP was not properly configured. After reboot, the times between the RTEMS clock and the NFS host would slowly drift apart ... and then save-restore would stop working and require a reboot.
> Just for grins, do a 'date' on the IOC and host to see if the times have substantially drifted apart.
Hi, Ned.
I rebooted the IOC, so it's not exhibiting the problem right now. I am
syncing the IOC's clock via an APS NTP server. Right now, the time on
the IOC is within a second of the time on the NFS server. When the
problem happens again, I'll try doing a 'date' on both as you suggest.
Thanks for your comments and suggestion,
Lewis
- Re: autosave failure S_rpcLib_RPC_CANTSEND Ned Arnold
Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
RE: autosave failure S_rpcLib_RPC_CANTSEND Mark Rivers
<2013>
PI C863's direction status can't change in time as leaving the limit switch Mi Qingru
<2013>
