Hello,
Thank you for your reply. According to your suggestion, we followed the
steps described in the stream device documentation
(HowToDoSerial(StreamDevice)) and try to run the example, but we got an
error:
drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0)
asynSetOption("L0", -1, "baud", "9600")
setOption failed tcsetattr failed: Input/output error
asynSetOption("L0", -1, "bits", "8")
asynSetOption("L0", -1, "parity", "none")
asynSetOption("L0", -1, "stop", "2")
asynSetOption("L0", -1, "clocal", "Y")
asynSetOption("L0", -1, "crtscts", "Y")
asynOctetSetInputEos("L0", -1, "\n")
asynOctetSetOutputEos("L0", -1, "\n")
asynSetTraceIOMask("L0",-1,0x2)
asynSetTraceMask("L0",-1,0x9)
and also when I type dbior "stream" command in epics I get the following
output:
Driver: stream
StreamDevice 2.6.0 built May 13 2013 15:00:53
registered bus interfaces:
DebugInterface
DummyInterface.
Can you help me to resolve this problems?
In the Tech-talk I found some notes about the last output where it is
suggested to make some changes in the CONFIG_STREAM file, but I could not
find such file in my directories. Where it is located?
Thanks in advance,
Vahe.
Agreed -- and please note that recent versions of the ASYN support module include a tutorial on using StreamDevice to communicate with a device.
On May 22, 2013, at 1:28 AM, Ralph Lange <[email protected]> wrote:
Hello Vahe,
I would strongly suggest using StreamDevice [1] to interface such a device.
This approach will be much easier and faster. Writing a protocol file for your device is basically all you will have to do.
~Ralph
Eric Norum
[email protected]
- Re: Gauge controller with R232 serial port Alan Greer
- RE: Gauge controller with R232 serial port Mark Rivers
- Gauge controller with R232 serial port Vahe Sahakyan
- Re: Gauge controller with R232 serial port Ralph Lange
- Re: Gauge controller with R232 serial port Eric Norum
Re: autosave failure S_rpcLib_RPC_CANTSEND Ned Arnold
Re: Status update during no motor in motion Mi Qingru
<2013>
<2013>
