Thanks for the responses, Andrew. FYI, the CHECK_RELEASE=YES build reports nothing bad. I did some experimentation and found that the inter-PV links seem to be generating the warnings. The INP and FLNK fields each generate one message each time the db file is loaded. If I delete those links, the errors go away. Exception: The INP for the actual hardware record is fine, VMIC0943 isn't complaining.
I tried some random changes, such as linking to RECORD.VAL instead of RECORD, specifying NPP NMS for the link type, but with no changes to behavior. Speaking of behavior, these records all seem to be functioning properly once loaded. Here's a live snapshot of one. INPA and FLNK each generated a warning on this one when loaded.
vxwrks@iocea2->dbpr "E201B06C0943ADDR3:mux1",9 A: 682 ACKS: NO_ALARM ACKT: YES ADEL: 0 ALST: 682 ASG: ASP: 0x1091680 B: 0
BKPT: 00 C: 0 CALC: A AND 65535 D: 0 DESC: limit switch DISA: 0 DISP: 0 DISS: NO_ALARM DISV: 1 DPVT: 0x0 DSET: 0x0 DTYP: <nil>
E: 0 EGU: EVNT: 0 F: 0 FLNK:PV_LINK E201B06C0943ADDR3:low G: 0 H: 0 HHSV: NO_ALARM HIGH: 0 HIHI: 0 HOPR: 0
HSV: NO_ALARM HYST: 0 I: 0 INPA:PV_LINK E201B06C0943ADDR3:ai NPP NMS INPB:CONSTANT INPC:CONSTANT INPD:CONSTANT INPE:CONSTANT INPF:CONSTANT
INPG:CONSTANT INPH:CONSTANT INPI:CONSTANT INPJ:CONSTANT INPK:CONSTANT INPL:CONSTANT J: 0 K: 0 L: 0 LA: 682 LALM: 682 LB: 0
LC: 0 LCNT: 0 LD: 0 LE: 0 LF: 0 LG: 0 LH: 0 LI: 0 LJ: 0 LK: 0 LL: 0 LLSV: NO_ALARM
LOLO: 0 LOPR: 0 LOW: 0 LSET: 0x10fd890 LSV: NO_ALARM MDEL: 0 MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 MLOK: 01 15 74 f0
MLST: 682 NAME: E201B06C0943ADDR3:mux1 NSEV: NO_ALARM NSTA: NO_ALARM PACT: 0 PHAS: 0 PINI: NO PPN: 0x0 PPNR: 0x0 PREC: 0 PRIO: LOW
PROC: 0 PUTF: 0 RDES: 0x142b860 RPCL: 03 01 40 ef ff e0 00 00 00 00 41 00 00 00 00 00 00 00 00 00 RPRO: 0 RSET: 0x15fb458 SCAN: Passive SDIS:CONSTANT
SEVR: NO_ALARM SPVT: 0x0 STAT: NO_ALARM TIME: 2013-05-24 12:37:15.118782174 TPRO: 0 TSE: 0 TSEL:CONSTANT UDF: 0 VAL: 682
value = 0 = 0x0 - Mike On Fri, May 24, 2013 at 5:07 PM, Andrew Johnson <[email protected]> wrote:
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
