Hi Zen,
To more directly answer your points in this message, recall that all asyn port drivers implement one or more asyn interfaces. Thus, although they don't export global functions, they do have a function table of those interface functions (int32->read, etc.) which are accessed via the pasynManager functions (findInterface, etc.)
Sent: Saturday, May 18, 2013 11:42 AM
To: Mark Rivers
Cc: [email protected]
Subject: Re: More on Modbus
Hi Mark,
I would like to try your suggestion. You may recall, that I have
written a C++ device driver for the New Focus Pico motor (mostly for
fun), using the asynMotorController and asynMotorAxis base classes. So I
think this aspect of the project should not be much of a problem.
I assume that the IO to hardware would be done via the modbus support
module.
I see that there is only one external function in the drvModbusAsyn.c file,
drvModbusAsynConfigure. I see the same thing in the modbusInterpose.c
file. I am assuming that my driver would link to the modbus library
(libmodbus.a). I have not yes figured out how the register read and
write is done in the modbus support module.
Anyway, could you sketch out how my driver would be integrated with the
modbus support module and how would the IO be done?
Thanks Mark,
Zen
On 05/18/13 08:45, Mark Rivers wrote:
> Hi Zen,
> Hi Zen,
> I think I see a solution that should allow you to stop the poller thread when you want to access the same Modbus addresses in another thread. The solution is to have the poller thread take the asyn port driver lock (pasynManager->lockPort()) for its operation loop. Your other thread can then also lock the port, which will block the poller thread while you do a sequence of write and read operations. This will work fine if your motor code is written as a C/C++ driver. But if it is just a collection of records in a database I'm not sure how to do it.
> Since the problematic Beckhoff devices are motor controllers, you could write a real driver in C++ using the asynMotorController and asynMotorAxis base classes, which are themselves derived from asynPortDriver. There are quite a few examples of relatively simple drivers using that model in the synApps motor module now. Such drivers are normally used with the synApps motor record, but this is NOT required. Since the driver uses standard asyn interfaces it is possible to just use standard records to move the motor, control the velocity, read the status, etc. You lose the "state machine" aspect of the motor record (backlash correction, retries, etc.). But for a simple controller the standard records may be fine. In your C++ driver you will then call lockPort() for the underlying Modbus driver when needed.
> I can make the appropriate minor change to the Modbus driver for you to test if this seems like a reasonable approach to you.
> Mark
> From: Zenon Szalata [[email protected]]
> Sent: Friday, May 17, 2013 4:39 PM
> To: Mark Rivers; [email protected]
> Subject: More on Modbus
> Hi Mark,
> Some of what I wrote in my previous email is no longer relevant. I have
> since played with controlling the polling timeout to reduce the
> interference between the reads done in the polling thread and the
> write-reads that I am attempting from my rather complicated set of EPICS
> records. I have reached a conclusion, hopefully correct, that what I
> really need is a Modbus device driver that would give me a full control
> when and in which order register read and write operations are performed.
> Is this possible with the existing Modbus support module?
> I am thinking that it would be very nice to have a C++ base class like
> asynPortDriver, or perhaps a subclass of asynPortDriver, which would
> implement all the details of Modbus protocol and basic IO.
> Have you thought of writing something like that?
> Do you think such a class would be useful?
> Beckhoff are the only modbus devices that I have written software for
> and the stepper motor controllers are the only devices for which I find
> your Modbus support module too limited. For that reason I am a bit
> hesitant to start a new project, that is to write the C++ class. Could
> you offer your insight on this?
> Thanks in advance,
> Zen
- More on Modbus Zenon Szalata
- RE: More on Modbus Mark Rivers
- Re: More on Modbus Zenon Szalata
<2013>
<2013>
