1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: How to output arrary data in EPICS db?
To: marco_hair <[email protected]>
Date: Wed, 15 May 2013 10:49:45 -0500 (CDT)
Hi Geyang,
I'm guessing there's a typo in your message, and the record $(id):waveform
is actually an aao record, because the waveform record has neither OUT nor FTVA
fields.  If so, the problem may be
field(FTVA, "SHORT")
because the aao record field that specifies the data type is FTVL.
Tim
----- Original Message -----
> From: "Silver" <[email protected]>
> To: "tech-talk" <[email protected]>
> Sent: Wednesday, May 15, 2013 8:47:10 AM
> Subject: How to output arrary data in EPICS db?
> hi, :
> I am using simens plc driver by dirk and want to write array data to
> plc. The array is read from a data file on disk. So I use sub record
> or gensub to get array. The db file is as following:
> record(genSub,"$(id):gensub")
>   field(SCAN, "Passive")
>   field(INAM, "genSubArrayInit")
>   field(SNAM, "genSubArrayOut")
>   field(OUTA, "$(id):waveform.VAL")
>   field(NOVA, "12")
> record(waveform,"$(id):waveform")
>   field(NELM, "12")
> The vala field of genSub record is a pointer to arrary data, I set it
> to waveform record’s val field. then use caget can get the array.
> But waveform is an input record, so I want to use aao record to
> implement the function. Kindly, dirk added aao support to the s7-plc
> driver. If use "caput –a xx xxx xxx", the aao record can write the
> array to hardware.
> So I change the db file like this:
>   field(OUTA, "$(id):aao.VAL")
>   field(NOVA, "12")
> #  field(FLNK,"$(id):aao")
>     field(SCAN, "I/O Intr")
>     field(DTYP,"S7plc")
>     field(OUT,"@Siemens_S7: 0/200 'T=SHORT'")
>     field(NELM, "12")
> But the IOC corrupted by Segement Default error. Seems there is a
> pointer error somewhere. I also tried to write a small code by using
> ezca library to write the array to aao record directly, it failed
> too. But the same code of ezcaPut can write array to waveform
> record.
> So, what’s the difference between waveform and aao in this case? Can
> anyone help me?
> Ps, I searched the tech-talk, Andy Foster said he has written a
> waveform out record long long ago, but the download url is invalid.
> Best wishes
> Geyang 2013-05-15
Re: How to output arrary data in EPICS db? Dirk Zimoch
How to output arrary data in EPICS db? Silver
Prev: Re: Open multiple OPI Hugo Slepicka
Next: Re: mmio in epics base Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: How to output arrary data in EPICS db? Silver
Next: Re: How to output arrary data in EPICS db? Dirk Zimoch
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
