1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: using the EPICS build system with an IDE
To: "Brown, Garth" <[email protected]>, "Tech Talk ([email protected])" <[email protected]>
Date: Tue, 14 May 2013 23:58:18 +0000
> I'm using Eclipse CDT, and I'm not sure if it doesn't have this problem, or if I
> didn't try the right test. I used an IOC app, typed "findThisError." on a random
> line in a source file, compiled, double clicked on the error message
> ("../drvSis3350.cpp:361: error: 'findThisError' was not declared in this scope"),
> and it took me to the right place.
This issue will of course be very specific to both the compiler and the IDE, and problems might be worse when you are working several levels down in base, IDK.
I currently see this issue with the code blocks IDE, and in the past also with certain debuggers although the issue with debuggers was some time back, and I don't remember the specifics at this point. As I recall, the EPICS build system works as-is with Visual C++ as long as one change some search path settings, but with some border case problem remaining with certain files. Visual C++ has been changing over the years so this may be less of a problem with the newer versions.
Jeff
> -----Original Message-----
> From: Brown, Garth [mailto:[email protected]]
> Sent: Tuesday, May 14, 2013 4:02 PM
> To: Hill, Jeff; Tech Talk ([email protected])
> Hi Jeff,
> Garth
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Hill, Jeff
> Sent: Tuesday, May 14, 2013 11:38 AM
> To: Tech Talk ([email protected])
> Furthermore, this simple patch to configure/RULES_BUILD appears to
> produce IDE compatible compiler output, which appears to be an
> improvement, from my perspective.
> @@ -210,15 +210,15 @@
>  %$(OBJ): %.c
>  	@$(RM) $@
> -	$(COMPILE.c) -c $<
> +	$(COMPILE.c) -c $(realpath $<)
>  %$(OBJ): %.cc
>  	@$(RM) $@
> -	$(COMPILE.cpp) -c $<
> +	$(COMPILE.cpp) -c $(realpath $<)
>  %$(OBJ): %.cpp
>  	@$(RM) $@
> > Sent: Tuesday, May 14, 2013 12:09 PM
> > Subject: using the EPICS build system with an IDE
> > Hi All,
> > I have noticed over the years that the EPICS build system isn't
> > particularly helpful when using an IDE because it doesn't generate
> > full source file paths on the compiler command line, and instead
> > subdirectory dependent relative paths are used. This seems to cause
> > gcc to produce also relative source file paths in its compiler
> > messages which can interfere with clicking on the error message and
> > vectoring the focus to the appropriate source file in the IDE. It
> > seems that gcc could easily provide an option to force generation of
> > full (not
> > relative) source file paths in its output no matter what the format is
> > of its input file paths might be, but AFAIKT, it doesn't.
> > However, maybe this post suggests a solution that could be applied
> > generically within the internals of the EPICS build system to produce
> > full path names in the compilers input while continuing to navigate
> > the build system with relative paths.
> > http://gcc.gnu.org/ml/gcc-help/2008-03/msg00084.html
> > This would result in rather more verbose build message output, but
> > would improve productivity when using an IDE from my perspective. I
> > suppose that we might also provide a configure option which determines
> > the type of compiler file path output that gets generated depending on
> > a particular user's needs, if that was important.
> > Comments?
> > Jeff
using the EPICS build system with an IDE Hill, Jeff
RE: using the EPICS build system with an IDE Hill, Jeff
RE: using the EPICS build system with an IDE Brown, Garth
Prev: Re: using the EPICS build system with an IDE Andrew Johnson
Next: RE: using the EPICS build system with an IDE Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: using the EPICS build system with an IDE Brown, Garth
Next: Re: using the EPICS build system with an IDE Andrew Johnson
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
