1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: using the EPICS build system with an IDE
To: [email protected]
Date: Tue, 14 May 2013 18:15:32 -0500
Hi Jeff,
On 2013-05-14 Hill, Jeff wrote:
> Furthermore, this simple patch to configure/RULES_BUILD appears to produce
> IDE compatible compiler output, which appears to be an improvement, from
> my perspective.
I can see the attraction for an IDE user, but for a regular command-line user
this pushes the gcc error messages way over to the right and in most cases on
to another line (note that the word-wrapping below does not match my terminal
output which is more ragged):
Original:
../../../src/std/softIoc/softMain.cpp:9: error: ‘syntax’ does not name a type
Using $(abspath $<):
/home/phoebus3/ANJ/epics/base/mirror-3.15/src/std/softIoc/softMain.cpp:9:
I would consider adding a build configuration parameter in the 3.15 version so
this could be enabled by those who want it, but I wouldn't want it to be the
default, which I think you suggested would be acceptable.
I have a simple and working solution which I will discuss with Janet tomorrow.
The tricky question is how far to go with using it — do the dependencies need
to be absolute?  What about calls to flex and antelope?  Resource compiler?
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
RE: using the EPICS build system with an IDE Hill, Jeff
Prev: RE: using the EPICS build system with an IDE Brown, Garth
Next: RE: using the EPICS build system with an IDE Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: using the EPICS build system with an IDE Hill, Jeff
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
