1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Modbus TCP and Omega
To: "'[email protected]'" <[email protected]>, "'EPICS Tech Talk'" <[email protected]>
Date: Mon, 13 May 2013 22:53:05 +0000
Hi Stefani,
I looked a little more closely at the Omega manual:
http://www.omega.com/manuals/manualpdf/M3397.pdf
On page 40 they give an example of setting Alarm2 to -100.0.  This is done in 2 steps:
- Set the decimal point to position 2 (FFF.F).
- Send the value -1000 in 2's complement format.
This shows that the meter does use 2's complement for signed integers.
-----Original Message-----
Sent: Monday, May 13, 2013 5:12 PM
To: '[email protected]'; EPICS Tech Talk
Hi Stefani,
Are you using my EPICS Modbus module?
When you say "it sends back its data as hex", how are you getting the 00 e6 value?  Using asynTrace?
I suspect the device is actually returning 16-bit binary data, which is the most common Modbus data type.
You need to look at the Omega manual to determine:
- How many bits is the data (12, 14, 16, etc.)
- What binary format does it use (2's complement, sign and offset, etc.)
I took a quick look at the Omega iSeries communications manual:
It has a reasonable description of their Modbus protocol.  However, I could not find a description of how they handle signed numbers - 2's complement or sign and offset.
You should then use a record definition like the following:
# ai record template for register inputs
record(ai, "$(P)$(R)") {
    field(DTYP,"asynInt32")
    field(INP,"@asynMask($(PORT) $(OFFSET) $(BITS))INT16")
    field(LINR,"LINEAR")
    field(EGUL,"$(EGUL)")
    field(EGUF,"$(EGUF)")
    field(HOPR,"$(EGUF)")
    field(LOPR,"$(EGUL)")
    field(PREC,"$(PREC)")
    field(SCAN,"$(SCAN)")
The UINT16 drvUser field assumes the device has signed 16-bit 2's complement data.  Other possibilities are UINT16 (unsigned 16-bit integers), INT16SM (16-bit integers in sign-magnitude format), etc.  This document provides more information:
http://cars9.uchicago.edu/software/epics/modbusDoc.html
Let me know if you have more questions or problems.
Cheers,
From: [email protected] [mailto:[email protected]] On Behalf Of S. Banerian
Sent: Monday, May 13, 2013 4:24 PM
To: EPICS Tech Talk
Subject: Modbus TCP and Omega
I have an Omega CNi853-EIT device, with thermocouple attached, which can
be accessed via Modbus TCP.
I've been able to get an IOC to query the Omega, and it does reply, but
it sends back its data as hex, so, e.g. 00 e6 is its representation for
230 (23.0 C).
In my databases, I've tried mbbi bi and ai  types, but probe tells me
the PV is always in an "invalid" state.
What would folks suggest I use to read this hex value?
Stefani Banerian
UW Clinical Cyclotron
UW School of Medicine
206-598-0302
gpg key 6642E7EE
fingerprint = BD13 875D 2D03 5E1D 1E3B  8BF7 F4B8 63AD 6642 E7EE
Re: Modbus TCP and Omega S. Banerian
RE: Modbus TCP and Omega Mark Rivers
Prev: RE: Modbus TCP and Omega Mark Rivers
Next: Relative time in XY graph Himanshu Tyagi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Modbus TCP and Omega S. Banerian
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
