I have been following Eric Norum's "How To Do Serial" guide ( http://www.aps.anl.gov/epics/modules/soft/asyn/R4-21/HowToDoSerial/tutorial.pdf) to write an application to control a serial port controller table top x-ray source.
So far everything works near perfectly (Thanks to Eric for the guide, and the writers of ASYN/EPICS), my only issue is that I am having trouble getting the Analog Input and Output fields to work properly. I can easily read and write the raw values (0 to 4095 due to it being a 12 bit DAC inside the xray's controller) but when I change the .db record to try and use ASYN's built in functions to convert the value I run in to issues. I'm definitely missing something that is probably obvious for most techtalk readers.
Here is one of the commands in the app source file.
{&DSET_AI, GPIBREAD, IB_Q_LOW, "RD1", NULL, 0, 127, NULL, 0, 0, NULL, NULL, NULL},
The controller responds to RD1 with 0000\r with 0000 being from 0000 to 4095. (I tried using the format function, i.e. with "%u\r" but this didn't seem to work, but with NULL it does.)
Here is the corresponding section of my db file. (which is how I was hoping it would work at first) srxr is the name of my device.
record(ai, "$(P)$(R):uAStatus")
field(DESC, "Read Xray uA Monitor")
field(SCAN, "1 second")
field(DTYP, "srxr")
field(LINR, "LINEAR")
field(ASLO, "0.244")
field(AOFF, "0")
field(EGUF, "900")
field(EGUL, "0")
field(EGU, "uA")
field(INP, "#L$(L) A$(A) @11")
I tried changing DTYP to asynInt32, and then changing INP to the @asyn format, but this did not seem to work.
I also tried to change several of the fields, such as LINR to SLOPE. So far I only get the field showing as 0 (when it should be reading
an output, or as the raw value.
Here are relevant portions of st.cmd
dbLoadDatabase "dbd/srxr.dbd"
srxr_registerRecordDeviceDriver pdbbase
## Load record instances
dbLoadRecords("db/devsrxr.db","P=srxr,R=,L=0,A=0")
drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0)
asynSetOption("L0", -1, "baud", "9600")
asynSetOption("L0", -1, "bits", "8")
asynSetOption("L0", -1, "parity", "none")
asynSetOption("L0", -1, "stop", "1")
asynSetOption("L0", -1, "clocal", "Y")
asynSetOption("L0", -1, "crtscts", "N")
As is, this just reads out the raw values of uA, rather than it being converted to EGU.
Alternatively someone can point me to example source code that runs a serial device, but is more complex
than the filter wheel in the "How To Do Serial" guide (uses more record types like ai etc).
I couldn't find any that helped me with this issue.
Andrew
- Re: Help beginner with ASYN device support, ai record conversion to EGU Eric Norum
Re: vxWorks localtime_r fails? (was epicsTimeGetEvent failed) Michael Davidsaver
Re: msi exitStatus bug Andrew Johnson
<2013>
EPICS Engineer Required James Cooke
<2013>
