1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: vxWorks localtime_r fails? (was epicsTimeGetEvent failed)
To: Geon-Yeong Mun <[email protected]>
Cc: [email protected]
Date: Mon, 13 May 2013 11:35:37 -0400
On 05/13/2013 01:52 AM, Geon-Yeong Mun wrote:
Starting timestamping
0x46ac410 (cbHigh): Unhandled C++ exception resulted in call to terminate
Thread cbHigh (0x46ac410) suspended
Timestamping timeout
epicsThread: Unexpected C++ exception "epicsTime_localtime failed" with type "St11logic_error" in thread "Watch Dog Timer" at <UKN DATE>
0x450a010 (Watch Dog Timer): Unhandled C++ exception resulted in call to terminate
I think that this message EVG’s(not EVR).
Can you explain this message?
It looks like a call to localtime_r() is failing.  Unfortunately I'm not certain what would cause this.
http://bazaar.launchpad.net/~epics-core/epics-base/3.14/view/head:/src/libCom/osi/os/vxWorks/osdTime.cpp#L71
Re: vxWorks localtime_r fails? (was epicsTimeGetEvent failed) Andrew Johnson
Re: Re: epicsTimeGetEvent failed Geon-Yeong Mun
Prev: EPICS Engineer Required James Cooke
Next: Re: vxWorks localtime_r fails? (was epicsTimeGetEvent failed) Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Re: epicsTimeGetEvent failed Geon-Yeong Mun
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
