The problem went away after I re-compiled base. Maybe I had a version
mismatch somewhere. Or a lib was broken during copy. Anyway, it works now!
Dirk
On 08.05.2013 17:15, J. Lewis Muir wrote:
On 5/8/13 4:37 AM, Dirk Zimoch wrote:
Hello,
I have a problem using epicsTimerQueueActive.
When I create a time queue with epicsTimerQueueActive::allocate(true)
then release it with epicsTimerQueueActive::release() and after that
call epicsTimerQueueActive::allocate(true) again, I get a segmentation
fault due to access to address 0.
I see no crash if I do not call release().
Interestingly, I see this effect only on my armv5teb (aka xscale_be)
embedded Linux system, but not on x86 or on p2020 ppc (big endian, too).
All accesses are in the same thread (_main_) during device initialization.
This happens when I use StreamDevice with at least two records connected
to a non-existing asynOctet port.
Any ideas?
Hi, Dirk.
What version of EPICS Base is this?
What compiler was used to build for armv5teb?
Does the problem also occur when built with all compiler optimizations
disabled (i.e. -O0)?
Lewis
- RE: Timer Queue crash Hill, Jeff
- Timer Queue crash Dirk Zimoch
- Re: Timer Queue crash J. Lewis Muir
RE: CSS 3.1.x PVManager / JCA ClassCastException marcus . michalsky
RE: CA subscription synchronisation shutdown problem michael.abbott
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
