1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: new archiver problem
Date: Sun, 12 May 2013 11:58:30 -0400
Hello all,
I've got an update on this problem.  The issue wasn't the time stamps, though those may prove another issue once this is fixed.  The problem I had was that the master_index file had reached its maximum size.  I copied it over to make room for a new one, edited indexupdate.xml to include only 2012 and later index files, then ran:
ArchiveIndexTool -v 1 indexupdate.xml master_index &
This being the command that appears over and over in the ArchiveIndexTool.log file, but no master_index file appeared.  The new master_index file was crated.  I have yet to see if it will be continually updated as master_index is taking a while to build and I think the automatic update happens around 2 am, but I don't see why it wouldn't run as before.
Thanks everyone for the help, I'll ask if any other problems come up.
James
On Fri, May 10, 2013 at 5:10 PM, James F Ross <[email protected]> wrote:
Andrew,
I tried rebooting some IOCs, but I'm still getting the time stamp errors in the archiver logs for those variables.  However I don't think the time stamp error is the cause of what is going on with the Archive Viewer as many variables with no time stamp errors also don't show up past april 27.
James
On Fri, May 10, 2013 at 4:59 PM, Andrew Johnson <[email protected]> wrote:
Hi James,
On 2013-05-10 James F Ross wrote:
> Well, using camonitor in the variables that are showing up with a bad time
> stamp, the time stamps are indeed bad.  Eg: <undefined> 0 UDF INVALID.
A timestamp of <undefined> almost always means that the associated record has
not been processed since the IOC was booted.  I'm going to guess that your
IOC(s) were rebooted on April 27th.
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
new archiver problem James F Ross
Re: new archiver problem Maren Purves
Re: new archiver problem James F Ross
Re: new archiver problem Andrew Johnson
Prev: Re: channel archiver questions James F Ross
Next: Re: SNC: evflags not available to escaped C Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: new archiver problem James F Ross
Next: Re: mmio in epics base Andrew Johnson
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
