1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: channel archiver questions
To: John Alexander Dobbins <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Sat, 11 May 2013 23:48:04 -0400
The problem was that the master index file had reached its maximum size (thanks to John Dobbins and Jiro Fujita for the help).  I would welcome suggestions on how to deal with the gap in the data from when this file maxed out to now.  Is there a way to get the archive engine to include all index files written after a certain date in the new master_index file?
James
On Sat, May 11, 2013 at 8:55 PM, John Alexander Dobbins <[email protected]> wrote:
James,
I have only used the 32 bit version so I am not familiar with the limitations of the 64 bit version.
With the 32 bit version we do the following:
Data more than 6 months old moves to tape. However the size of the index file constantly grows as it still contains entries for data moved to tape. When the master index reaches 2 GB (producing the symptom you describe) we rebuild the master index with the index tool (described in the Archiver manual). No data is lost in the process. After rebuild the master index might be 1GB, but this will last us many months.
John
Sent: Saturday, May 11, 2013 7:09 PM
This is, I believe, the 64 bit version.  The master_index file is over 2G though...  Hmm.  If the memory size is the issue, any suggestions for how to reduce the size without losing recent data?  And, just as important, include the data since April 27th?
Thanks
James
On Sat, May 11, 2013 at 6:41 PM, John Dobbins <[email protected]> wrote:
Is this a 32 bit version? The Max size for master index is 2G. Could your index have reached this size?
John Dobbins
Sent: Sat May 11 18:25:32 EDT 2013
To: EPICS Tech Talk <[email protected]>
Subject: channel archiver questions
Hello all,
The epics channel archiver running here at STAR is behaving strangely.  The problem is that I can't see any variable values in archive viewer after April 27th around 10 am.  However, there are index files being written by each engine up through today.  The index files are of a typical size, so they have information in them, but for some reason it isn't showing up.
Perhaps there is a problem in whatever mechanism combines the individual index files into the master index file for the entire archiver?  Does anyone have an experience with a problem like this?
Thanks very much!
James
channel archiver questions James F Ross
Prev: channel archiver questions James F Ross
Next: Re: new archiver problem James F Ross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: new archiver problem James F Ross
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
