I have Ubuntu 11.4 Installed. I want to Install EPICS
Base and MEDM following Instructions on (Download the
distributions tarballs from EPICS.doc attached) . please
refer to Configure the Extensions Section in this File.
EPICS Base is Installed and Compiled (Base Installation
Attached)
While Compiling MEDM the erorr occures during make
(extensions error attached)
kindly let me tell that how can I compile MEDM properly.
Also what are other alternatives to MEDM. CSS is just like MEDM
or some other thing.
An Early Response is required
Regards
Murad Ali
If you want to get started fast, try using the binary packages
provided by Michael Davidsaver at NSLS-II. They should work on
Debian based distributions.
http://epics.nsls2.bnl.gov/debian/
As for the alternatives for MEDM, there are a number of them. Which
one is suited best for your application depends on your specific
needs.
In general, it is safe to say that EDM is newer than MEDM and has a
roughly similar set of features.
~Ralph
- EPICS Extensions Compilation Errors murad ali
AW: EPICS Extensions Compilation Errors Zimoch Dirk
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
