ok,thank you.
发自我的小米手机
Till Straumann <[email protected]>编写:
>If you look at epicsSingleton.h then you'll find that the _build() method
>just invokes 'new'.
>The bad news are that when an operation involving the memory allocator
>results in a segmentation fault then that is in most cases due to heap
>corruption (e.g., because of a buffer overrun). The code which is to blame
>is often entirely unrelated to where the crash happens.
>- Till
>On 04/22/2013 12:23 PM, Rod Nussbaumer wrote:
>> Hi all.
>> Below is pasted the debug output from an IOC running under gdb. The IOC
>> repeatably segfaults whenever asSetFilename is called with an
>> access-security file that works on other IOCs.
>> The IOC in question is running on Linux:
>>> Linux icarm178 2.6.21-ts #4 PREEMPT Wed Jan 27 17:12:25 MST 2010 armv4tl GNU/Linux
>> on an ARM that otherwise runs IOCs reliably.
>> The segmentation fault occurs at some point during iocInit. I cannot
>> really tell where or how to look more closely.
>> The 'asInit...' messages
>> seen here are from some printf()s I put into the asInitCommon function
>> in asDbLib.c while trying to sort out the problem.
>> Looking for any pointers on where or how to focus further diagnostics.
>> Thanks.
>> Rod Nussbaumer
>> ISAC Controls, TRIUMF
>> Vancouver, Canada
>>> iocInit
>>> [New Thread 32769 (LWP 2488)]
>>> [New Thread 16386 (LWP 2489)]
>>> Starting iocInit
>>> ## EPICS R3.14.12.2 $Date: Mon 2011-12-12 14:09:32 -0600$
>>> ## EPICS Base built Aug 31 2012
>>> [New Thread 32771 (LWP 2490)]
>>> [New Thread 49156 (LWP 2491)]
>>> [New Thread 65541 (LWP 2492)]
>>> [New Thread 81926 (LWP 2493)]
>>> [New Thread 98311 (LWP 2494)]
>>> [New Thread 114696 (LWP 2495)]
>>> [New Thread 131081 (LWP 2496)]
>>> [New Thread 147466 (LWP 2497)]
>>> [New Thread 163851 (LWP 2498)]
>>> [New Thread 180236 (LWP 2499)]
>>> [New Thread 196621 (LWP 2500)]
>>> [New Thread 213006 (LWP 2501)]
>>> [New Thread 229391 (LWP 2502)]
>>> [New Thread 245776 (LWP 2503)]
>>> asInit: entered
>>> asInitCommon: entered
>>> asInitCommon: calling asInitFile
>>> asInitCommon: returned from asInitFile
>>> asInitCommon: calling asCaStart
>>> [New Thread 262161 (LWP 2504)]
>>> Program received signal SIGSEGV, Segmentation fault.
>>> [Switching to Thread 262161 (LWP 2504)]
>>> 0x0008b640 in epicsSingleton<localHostName>::_build () at ../../../include/epicsSingleton.h:187
>>> 187 ../../../include/epicsSingleton.h: No such file or directory.
>>> in ../../../include/epicsSingleton.h
>>> Current language: auto; currently c++
>>> (gdb) bt
>>> #0 0x0008b640 in epicsSingleton<localHostName>::_build () at ../../../include/epicsSingleton.h:187
>>> #1 0x000f80d0 in SingletonUntyped::incrRefCount (this=0x14ed64, pBuild=0x8b624 <epicsSingleton<localHostName>::_build()>)
>>> at ../../../src/libCom/cxxTemplates/epicsSingletonMutex.cpp:48
>>> #2 0x0008b5c8 in reference (this=0x1a94bc, es=@0x14ed64) at ../../../include/epicsSingleton.h:85
>>> #3 0x0008b614 in epicsSingleton<localHostName>::getReference (this=0x14ed64) at ../../../include/epicsSingleton.h:205
>>> #4 0x000b65bc in cac (this=0x1a94b0, mutualExclusionIn=@0x1a92c8, callbackControlIn=@0x1a92cc, notifyIn=@0x1a9258) at ../cac.cpp:150
>>> #5 0x00097330 in ca_client_context::createNetworkContext (this=dwarf2_read_address: Corrupted DWARF expression.
>>> ) at ../ca_client_context.cpp:730
>>> #6 0x0007148c in dbContext::createChannel (this=0x1a9420, guard=@0x7d9ff9bc, pName=0x1aca70 "ITW:ACCESS:CONSOLE1", notifyIn=@0x1acdc0, priority=0) at ../dbContext.cpp:104
>>> #7 0x0009768c in ca_client_context::createChannel (this=0x1a9258, guard=@0x7d9ff9bc, pChannelName=0x1aca70 "ITW:ACCESS:CONSOLE1", chan=@0x1acdc0, pri=0)
>>> at ../ca_client_context.cpp:668
>>> #8 0x000a3c04 in oldChannelNotify (this=0x1acdc0, guard=@0x7d9ff9bc, cacIn=@0x1a9258, pName=0x1aca70 "ITW:ACCESS:CONSOLE1", pConnCallBackIn=0x4fa70 <connectCallback>,
>>> pPrivateIn=0x1aca58, priority=0) at ../oldChannelNotify.cpp:54
>>> #9 0x0008cf3c in ca_create_channel (name_str=0x1aca70 "ITW:ACCESS:CONSOLE1", conn_func=0x4fa70 <connectCallback>, puser=0x1aca58, priority=0, chanptr=0x1a94a8)
>>> at ../access.cpp:333
>>> #10 0x0008d2a4 in ca_search_and_connect (name_str=0x1aca70 "ITW:ACCESS:CONSOLE1", chanptr=0x1a94a8, conn_func=0x4fa70 <connectCallback>, puser=0x1aca58) at ../access.cpp:297
>>> #11 0x0004f620 in asCaTask () at ../asCa.c:184
>>> #12 0x001149d4 in start_routine (arg=<value optimized out>) at ../../../src/libCom/osi/os/posix/osdThread.c:385
>>> #13 0x2aacefb0 in pthread_start_thread () from /lib/libpthread.so.0
>>> #14 0x2aacefb0 in pthread_start_thread () from /lib/libpthread.so.0
>>> #15 0x2aacefb0 in pthread_start_thread () from /lib/libpthread.so.0
RE: caget delays Mark Rivers
RE: Add choice to dbd file Emmanuel Mayssat
<2013>
RE: Crash when using access security Hill, Jeff
<2013>
