Hi 周永年,
On 2013-04-22 周永年 wrote:
> When we started to executing the startup script st.cmd at :
> ld<systemO/system.munch
> sysAtReboot not found. epicsExit will not be called by reboot.
> According to http://www.aps.anl.gov/epics/tech-talk/2005/msg00004.php , I
> added the two routines in bootConfig.c.
bootConfig.c is only used when building a bootrom and is not included in the
VxWorks OS image so it won't work properly if you put it there. The above
message was not clear where to put these changes, my apologies about that.
It is easiest to put everything in the vxWorks/target/src/config/usrNetwork.c
file. The two functions and the Hook variable definition would go after all
the variable declarations (make sure they are outside of any ifdef INCLUDE_*
guards), and then the call to rebootHookAdd belongs inside the usrNetInit()
routine, just before the call to hostTblInit().
Don't forget to remove the changes from your bootConfig.c file again. Then
build a vxWorks boot image using "make vxWorks" or "make vxWorks.st" as you
normally do and boot that OS image; you do not have to reprogram the vxWorks
bootrom on your CPU.
Hope this helps,
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
- and Speaking of sysAtReboot.... Bjorklund, Eric A
- Andrew 周永年
Re: genesys power supply IOC James F Ross
RE: genesys power supply IOC Mark Rivers
<2013>
Andrew 周永年
<2013>
