1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Andrew
Date: Mon, 22 Apr 2013 07:26:45 +0000
Hello, Andrew!
I'm Zhou Yong-nian at SSRF,Shanghai,China.
When we started to executing the startup script st.cmd at :
 ld<systemO/system.munch
sysAtReboot not found. epicsExit will not be called by reboot.
According to http://www.aps.anl.gov/epics/tech-talk/2005/msg00004.php , I added the two routines in bootConfig.c.
In the routine"int sysAtReboot(VOIDFUNCPTR closedown)", the parameter closedown is undeclared.So when I build the bootrom.bin,there is the error message:
C:\Tornado2.2\target\config\mv5500>make bootrom.bin
ccppc -c -mcpu=604 -mstrict-align  -ansi  -O2 -fvolatile -fno-builtin -Wall -I/h
   -I. -IC:\Tornado2.2\target\config\all -IC:\Tornado2.2\target/h -IC:\Tornado2.
2\target/src/config -IC:\Tornado2.2\target/src/drv -DCPU=PPC604 -DTOOL_FAMILY=gn
u -DTOOL=gnu  -DMV5500    C:\Tornado2.2\target\config\all\bootConfig.c
C:\Tornado2.2\target\config\all\bootConfig.c: In function `bootLoad':
C:\Tornado2.2\target\config\all\bootConfig.c:2164: `closedown' undeclared (first
 use in this function)
C:\Tornado2.2\target\config\all\bootConfig.c:2164: (Each undeclared identifier i
s reported only once
C:\Tornado2.2\target\config\all\bootConfig.c:2164: for each function it appears
in.)
C:\Tornado2.2\target\config\all\bootConfig.c: In function `sysRebootHook':
C:\Tornado2.2\target\config\all\bootConfig.c:4982: warning: implicit declaration
 of function `cplusDtors'
make: *** [bootConfig.o] Error 0x1
It seems that the parameter 'closedown' is undeclared.
How do you make this two routines work?
Please help us with the error message.We are looking forward to your reply!
Thanks!
Sincerely yours,
Zhou Yong-nian
Re: Andrew Andrew Johnson
Prev: RE: Gige performance increasing. Ahed Aladwan
Next: RE: Calling ca_context_create(1) too late michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Gige performance increasing. Mark Rivers
Next: Re: Andrew Andrew Johnson
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
