1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Calling ca_context_create(1) too late
To: Tim Mooney <[email protected]>, michael abbott <[email protected]>
Date: Fri, 19 Apr 2013 15:00:40 +0000
That is exactly the problem I fixed recently in the epics/extensions/src/ezcaIDL code.  ezcaIDL calls functions in 2 other libraries:
ezca
EzcaScan
ezca calls ca_context_create with preemptive callbacks.  EzcaScan does not call ca_context_create, it relies on automatic creation of a context.  The problem was that if a function in ezca was called first, everything was fine.  But if a function in EzcaScan was called first then the call to ca_context_create in ezca failed, and things did not work.  I fixed it by guaranteeing that a function in ezca was always called before any function in EzcaScan.
From: [email protected] [[email protected]] on behalf of Tim Mooney [[email protected]]
Sent: Friday, April 19, 2013 9:31 AM
To: michael abbott
Cc: [email protected]
Subject: Re: Calling ca_context_create(1) too late
Is there any chance you've made any CA calls before calling ca_context_create()?
If so, CA might have made a call to ca_context_create() for you, and may not have
enabled preemptive callbacks, which I understand that you have to enable on an ioc.
saveData calls ca_context_create() after iocInit, so I'm pretty sure that's not
the problem.
Tim
----- Original Message -----
> From: "michael abbott" <[email protected]>
> To: [email protected]
> Sent: Friday, April 19, 2013 8:44:09 AM
> Subject: Calling ca_context_create(1) too late
> I've just discovered that calling ca_context_create(1) after
> iocInit() appears to succeed (it returns ECA_NORMAL) ... but the
> resulting context is not very healthy!  In my particular case I find
> that ca_array_get_callback delivers zero length data, but I expect
> other deeper problems are to be found.
> I understand that I need to call ca_context_create() a good deal
> earlier, but I don't really understand why it appears to succeed --
> is it possible for an error code to be returned instead, please?
>  (In some future version of EPICS, I'm testing this on 3.14.11.)
> Alternatively, is there some reliable way I can test whether it has
> succeeded?  I don't have full control over when my library is
> initialised, so detecting an error immediately would be more
> friendly to the user.
> This e-mail and any attachments may contain confidential, copyright
> and or privileged material, and are for the use of the intended
> addressee only. If you are not the intended addressee or an
> authorised recipient of the addressee please notify us of receipt by
> returning the e-mail and do not use, copy, retain, distribute or
> disclose the information in or attached to the e-mail.
> Any opinions expressed within this e-mail are those of the individual
> and not necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> attachments are free from viruses and we cannot accept liability for
> any damage which you may sustain as a result of software viruses
> which may be transmitted in or with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in
> England and Wales with its registered office at Diamond House,
> Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11
> 0DE, United Kingdom
Calling ca_context_create(1) too late michael.abbott
Re: Calling ca_context_create(1) too late Tim Mooney
Prev: Re: Calling ca_context_create(1) too late Tim Mooney
Next: Re: Calling ca_context_create(1) too late Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Calling ca_context_create(1) too late michael.abbott
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
