> With no /dev/ttyUSB* device files, what happens if the second device is
> plugged in first?
Without unplugging the devices I can unload the driver
Colorado:motor/iocBoot/iocWithAsyn>sudo modprobe -r -v ftdi_sio
rmmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/ftdi_sio.ko
rmmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/usbserial.ko
At this point there are no /dev/ttyUSB devices:
Colorado:motor/iocBoot/iocWithAsyn>ls -l /dev/ttyUSB*
ls: No match.
Now I load the driver for model 3006
Colorado:motor/iocBoot/iocWithAsyn>sudo modprobe -v ftdi_sio vendor=0x104d product=0x3006 debug
insmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/usbserial.ko
insmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/ftdi_sio.ko vendor=0x104d product=0x3006 debug
It works, and ttyUSB0 exists:
Colorado:motor/iocBoot/iocWithAsyn>ls -l /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 0 Apr 18 15:09 /dev/ttyUSB0
Now I unload the driver again:
No /dev/ttyUSB devices:
ls: No match.
Now I load the driver but for model 3000 this time:
Colorado:motor/iocBoot/iocWithAsyn>sudo modprobe -v ftdi_sio vendor=0x104d product=0x3000 debug
insmod /lib/modules/2.6.35.10-74.fc14.x86_64/kernel/drivers/usb/serial/ftdi_sio.ko vendor=0x104d product=0x3000 debug
So it works. But I don't know how to also have it recognize the second device. As Andrew said, loading the driver again does nothing:
I'll look into udev.
Sent: Thursday, April 18, 2013 2:17 PM
To: Mark Rivers
Cc: [email protected]
Subject: Re: Linux USB serial questions
On 4/18/13 1:21 PM, Mark Rivers wrote:
> Thanks for all the replies I've received so far. I am still reading and understanding them.
> But now I have a more fundamental question, there is something I am not understanding about modprobe I think.
> I now have 2 different USB ftdi_sio devices. Both are manufactured by Newport but they are different models.
> This is what lsusb shows for these devices:
> Colorado:motor/iocBoot/iocWithAsyn>/usr/sbin/lsusb
> Bus 004 Device 007: ID 104d:3006 Newport Corporation
> Bus 002 Device 004: ID 104d:3000 Newport Corporation
> Initially I plugged in the device with model=3006. I then did modprobe to load the ftdi_sio driver for that vendor and model, and it created /dev/ttyUSB0. It works fine, I can control it with no problems.
> Now I plugged in the second device with model=3000, leaving the first device also plugged in. The new device shows up with lsusb, as seen above. However, it did not create a /dev/ttyUSBn for that device.
> I then tried to run modprobe for the new device:
>> sudo modprobe ftdi_sio vendor=0x104d product=0x3000
> There is no error message. However, it did not create a new /dev/ttyUSBn device:
>> ls -l /dev/ttyUSB*
> crw-rw-rw- 1 root dialout 188, 0 Apr 18 13:10 /dev/ttyUSB0
> There is still only device ttyUSB0, not a new ttyUSB1.
> What am I doing wrong?
Hi, Mark.
plugged in first? Does it get assigned /dev/ttyUSB0?
Another thing to try would be to add the "debug" keyword to the end of
the modprobe command, and see if you get anything helpful in dmesg (or a
log file).
Lewis
- Re: Linux USB serial questions Jennings Guy
- Re: Linux USB serial questions J. Lewis Muir
- Linux USB serial questions Mark Rivers
- RE: Linux USB serial questions Mark Rivers
Re: Linux USB serial questions Andrew Johnson
<2013>
<2013>
