Subject: |
Re: sscan/ saveData problem with RW permission, and not an NFS issue |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Tue, 16 Apr 2013 10:31:57 -0500 |
Hi Tim,
On 2013-04-16 Tim Mooney wrote:
> Thanks for the information. I haven't tested sscan on vxWorks 6.9, though
> I'm told it works on vxWorks 6.8. I don't think creat() uses O_RDRW as a
> file-permission mask, and I don't understand why open() would work while
> creat() does not. I'm ok with making this change, but I'd like to
> understand it better first.
I don't think there's going to be any difference in the behavior between
VxWorks 6.8 and 6.9. This is one of those things that I believe Wind River
got wrong very early in the life of VxWorks and it has never been fixed
properly. This is from the documentation for creat():
The parameter mode is set to O_RDONLY (0), O_WRONLY (1), or O_RDWR (2)
for the duration of time the file is open. On NFS and POSIX compliant
file systems such as HRFS, mode refers instead to the UNIX style file
permission bits.
They even say that the second argument has a different meaning on different
file-systems, which means there is /no/ way to write code using this routine
that works properly on all file-systems, because you have to know what kind of
file-system it is to give the right parameter.
I recommend that creat() not be used in code that runs on vxWorks, and that
all calls to it be replaced with the equivalent open() call instead. The
Linux man-page for creat() says:
creat() is equivalent to open() with flags equal to
O_CREAT|O_WRONLY|O_TRUNC.
You will also need to add the mode parameter 0666.
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
- Re: sscan/ saveData problem with RW permission, and not an NFS issue Tim Mooney
EPICS UTC Time conversion Eric Norum
<2013>
RE: sscan/ saveData problem with RW permission, and not an NFS issue Vesna Samardzic-Boban
<2013>
