Hello
all.
I have an OPI that sends some
data to Stream Device records that are connected to an
equipment using serial RS232. This operation is started with a button
press. I don't want this button to be pressed again while the data is
being transfered to my equipment. So, I tried to disable the button in the
beginnig of the script, and reenable it at the end. But what I see is
an enabled button until the end of the data transfer. Only at the end of the
script I can see a quick transition of the button to disabled state and again to
enabled.
Between each data I need to
transfer, I use time.sleep, because my equipment need some time to
process the data before receiveing the next one.
My python script is the
following:
button = widgetController.getWidgetModel()
button.setPropertyValue("enabled", False)
button.setPropertyValue("text", "Programming\nPlease,
Wait")
(data transfer code, with some time.sleep functions...)
button.setPropertyValue("text", "Program Furnace")
button.setPropertyValue("enabled", True)
Is there a way to force the OPI refresh, as
the disabled status of the button is shown?
Márcio Paduan Donadio Engenheiro de Computação - Software de
Operação das Linhas de Luz Laboratório Nacional de Luz Síncrotron ?
(LNLS) Centro Nacional de Pesquisa em Energia e Materiais (CNPEM) + 55
(19) 3512-3520 - [email protected]www.lnls.cnpem.br
- Re: CSS opi refresh Kasemir, Kay
Re: Problem in installing asyn4-19 in mint13 system Eric Norum
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
