Hello Kay et al. However, lower down I get missing bundle errors for org.csstudio.archive.rdb_3.0.1 and org.csstudio.archive.rdb_3.1.1. I don't know if this is progress, but it is different. Full error log is below.An update. I managed to get org.csstudio.archive.rdb to be recognized. I had been using the exact version that the errors called for (3.0.1) extracted to a new project from a .jar file. Now I see an error in the log file where org.csstudio.archive.rdb is missing org.eclipse.help_0.0.0, which I don't seem to have (I have 3.5.1 but that doesn't seem to work). Thanks James !SESSION 2013-04-12 14:14:59.472 ----------------------------------------------- eclipse.buildId=unknown java.version=1.6.0_37 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US Framework arguments: -product org.csstudio.archive.engine.engine Command-line arguments: -product org.csstudio.archive.engine.engine -data /home/sysuser/CSS/cssTest/css-nsls2/workspace/../runtime-ArchiveEngine.product -dev file:/home/sysuser/CSS/cssTest/css-nsls2/workspace/.metadata/.plugins/org.eclipse.pde.core/ArchiveEngine.product/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog !ENTRY org.eclipse.osgi 2 0 2013-04-12 14:15:00.038 !MESSAGE One or more bundles are not resolved because the following root constraints are not resolved: !SUBENTRY 1 org.eclipse.osgi 2 0 2013-04-12 14:15:00.039 !MESSAGE Bundle initial@reference:file:../../../home/sysuser/CSS/cssTest/css-nsls2/plugins/org.csstudio.archive.rdb_3.1.1.201211061437.jar/ was not resolved. !SUBENTRY 2 org.csstudio.archive.rdb 2 0 2013-04-12 14:15:00.039 !MESSAGE Missing required bundle org.eclipse.help_0.0.0. !ENTRY org.eclipse.osgi 2 0 2013-04-12 14:15:00.039 !MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists: !SUBENTRY 1 org.eclipse.osgi 2 0 2013-04-12 14:15:00.040 !MESSAGE Bundle org.csstudio.archive.config.rdb_1.0.0.qualifier [24] was not resolved. !SUBENTRY 2 org.csstudio.archive.config.rdb 2 0 2013-04-12 14:15:00.040 !MESSAGE Missing required bundle org.csstudio.archive.rdb_3.0.1. !SUBENTRY 1 org.eclipse.osgi 2 0 2013-04-12 14:15:00.040 !MESSAGE Bundle org.csstudio.archive.writer.rdb_1.0.0.qualifier [28] was not resolved. !SUBENTRY 2 org.csstudio.archive.writer.rdb 2 0 2013-04-12 14:15:00.040 !MESSAGE Missing required bundle org.csstudio.archive.rdb_3.0.1. !SUBENTRY 1 org.eclipse.osgi 2 0 2013-04-12 14:15:00.040 !MESSAGE Bundle org.csstudio.archive.rdb_3.1.1.201211061437 [97] was not resolved. !SUBENTRY 2 org.csstudio.archive.rdb 2 0 2013-04-12 14:15:00.040 !MESSAGE Missing required bundle org.eclipse.help_0.0.0. !ENTRY org.eclipse.osgi 4 0 2013-04-12 14:15:00.040 !MESSAGE Application error !STACK 1 java.lang.RuntimeException: Application "org.eclipse.ant.core.antRunner" could not be found in the registry. The applications available are: org.csstudio.archive.engine.application, org.eclipse.equinox.app.error. at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248) at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577) at org.eclipse.equinox.launcher.Main.run(Main.java:1410) at org.eclipse.equinox.launcher.Main.main(Main.java:1386) On Fri, Apr 12, 2013 at 1:54 PM, James F Ross <[email protected]> wrote:
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
