Hi Vishnu,
Hi Vishnu,
It sounds like you need an asynPortDriver driver that has a writeOctet method that basically calls system(“string”) or execl( “path”, “arg”, ... ) and catches
the response from stdout in the readOctet method. I don’t think such a beast exists but if you took the asynPortDriver documentation (http://www.aps.anl.gov/epics/modules/soft/asyn/R4-21/asynPortDriver.html)
and the example I don’t think it would take long to write. You could then use StreamDevice or an asyn record to work out what to do with the reply.
I am posting this to techtalk in case anyone has done this as an exercise and not published it yet.
Cheers,
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
Actually i want to develop asyn based device support, so that EPICS PV have status of particular board is present or not in the system.
In my linux layer for each board one file is generated in /dev/XXX at boot time.
so if i can read the XXX file is present or not in /dev directory, EPICS PV can display the status of perticular board.
Vishnu
Sent: Wed, 10 Apr 2013 13:48:48
To: <[email protected]>, <[email protected]>
Subject: Re: linux file search from Asyn
HI Vishnu,
You have to provide more information about what you want to do. Do you want to somehow implement an asyn support layer that implements a search (which I don't really understand) or do you just want to find where the asyn support code is in your file system.
If the latter, the asyn device support file are in the asyn/devEpics directory of the asyn support module.
Cheers,
Nick Rees
From: [email protected] [mailto:[email protected]] On Behalf Of Vishnu Patel
Sent: 10 April 2013 08:26
To: techtalk
Subject: linux file search from Asyn
Dear all,
I want to search specific linux file in ayn Device support layer. how is it possible?
Thanks
Get your own FREE website and domain with business email solutions, click here
Get your own
click here
Re: Stream Device and Asyn Dirk Zimoch
Re: linux file search from Asyn Vishnu Patel
<2013>
Re: Conversion problem from double to 32 bit unsigned int (in ao) Benjamin Franksen
RE: linux file search from Asyn Mark Rivers
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
